Forums › The Car › 206 Talk › fitting bearings and top mount |
Posted: Sat Feb 05, 2011 9:07 am |
well doing strut tomorrow, so is there any last minute advice?
Posted: Sat Feb 05, 2011 9:10 am |
eat more before you do the job?
pain in the a** to remove the strut from the hubs if it hasn't been touch since is coming out from the factory.
Posted: Sat Feb 05, 2011 9:12 am |
Seabook wrote: |
pain in the a** to remove the strut from the hubs if it hasn't been touch since is coming out from the factory. |
oh bollox, i very much doute she has been touched,
Posted: Sat Feb 05, 2011 9:24 am |
A chunky hammer is helpful.
Posted: Sat Feb 05, 2011 9:28 am |
Edward wrote: |
A chunky hammer is helpful. |
got meself a pack hammer lol
Posted: Mon Feb 07, 2011 8:34 am |
i really cant belive how hard this is, its not the job its self, its the fact that every bolt is rusted on, just had to change the track rod ball joint because i had to cut the f****r off. this was the second time ive tried to do this job, other day it was the lower bolt that stopped me, because i didnt have a deep 16mm socket, had to rebuild car and go buy one lol.
now ive had to stop because the caliper bolts wont come undone. also smashed my head on jack, nice hole from that, put my back out 5 mins later. getting p**sed off with this 206 big time.
Posted: Mon Feb 07, 2011 8:42 am |
Just undo the hub pinch bolt and smack the hub down.
No need to do the other ones, just that and the drop link
Thats all i had to do anyway
