Posted: Mon Feb 07, 2011 7:26 am |
CD-vRS wrote: |
Laurenyt680 wrote: |
Ape wrote: |
What model is your 206?
I changed a head in about 3-4 hours the first time I did it. Stripping everything back takes the time, it can be done quite quickly. The time consuming bit is getting the head skimmed (if needed, but recommended). It can be done yourself (or your boyfriend/dad) if you're not too bad with spanners and a Haynes book.
I'll see if I can find the pictures I took when I did mine, was almost a step by step photo walkthrough. |
Those pictures would be great if you can find them for me!
It's a Peugeot 206 Lx 1999 - just feel its a shame when i havent had it for too long, want to give it a fighting chance! |
What size is the engine? |
Sorry missed that out.. its a baby 1.1 ![Smile Smile](images/smiles/icon_smile.gif)
| | ![](images/spacer.gif) |
Posted: Mon Feb 07, 2011 8:26 am |
can you show us some pictures of what you are explaining as pictures speak a thousand words ![Smile Smile](images/smiles/icon_smile.gif)
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Mon Feb 07, 2011 9:55 am |
leigh_boy wrote: |
can you show us some pictures of what you are explaining as pictures speak a thousand words ![Smile Smile](images/smiles/icon_smile.gif) |
Well I've cleaned the gunk now and don't really want to run it so that it's steaming/over flowing again as I'm afraid I'll cause more damage... Going to sort the head gasket 'myself' (with a little help from someone who knows more than I do of course!) and then see where it goes from there I think.
Posted: Mon Feb 07, 2011 10:05 am |
ok well good luck and dont be afraid to ask questions no matter how silly you might think it sounds.
| *DEAD*206 Gti 138
Posted: Mon Feb 07, 2011 10:18 am |
you need to skimmed the head when changing the head gasket. otherwise you will have to change the gasket again next month
Posted: Mon Feb 07, 2011 10:51 am |
Seabook wrote: |
you need to skimmed the head when changing the head gasket. otherwise you will have to change the gasket again next month |
Yeahhh I had the same advice from a guy I work with, Hopefully be doing it at the weekend, I'll update on how things go...
Thanks ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Mon Feb 07, 2011 12:32 pm |
The head skimming takes the time. I did a mates Rover and by the time I had the head off, took the valves out, taken to the machine shop (who had it for a week) re-ground the valves, replaced the valve stem oil seals, rebuilt his car, he decided that he didn't need it and bought a push bike instead.
