Posted: Mon Feb 07, 2011 11:23 am |
Posted: Mon Feb 07, 2011 11:24 am |
make sure you got the correct fittment as there is 2 tyres of fittment for gti brake
Posted: Mon Feb 07, 2011 11:25 am |
Seabook wrote: |
make sure you got the correct fittment as there is 2 tyres of fittment for gti brake |
The gti Brakes i have are same as the ones on a 2.0 hdi or d-turbo. if that matters
^^^^^^ I made that fault when i got mine they was 2 types of pads and 2 different gti calipers
Posted: Mon Feb 07, 2011 11:27 am |
Yep, discs & pads are different on both versions. Different offset on the discs & pads are shaped differently
Posted: Mon Feb 07, 2011 11:28 am |
Liam-HuTcH wrote: |
Seabook wrote: |
The gti Brakes i have are same as the ones on a 2.0 hdi or d-turbo. if that matters |
you need to know whether you got the lucas calipers or bosch calipers
Posted: Mon Feb 07, 2011 11:33 am |
Seabook wrote: |
Liam-HuTcH wrote: |
Seabook wrote: |
you need to know whether you got the lucas calipers or bosch calipers |
bosch
Posted: Mon Feb 07, 2011 11:39 am |
If they are the right discs they are £10 cheaper on nextdaybrakes.com with free next day delivery
Liam-HuTcH wrote: |
Seabook wrote: |
Liam-HuTcH wrote: |
Seabook wrote: |
bosch |
which year?
99 to 01 most likely is still using the 266x20.5 disc
02 or newer will use the 266x22 disc
Posted: Mon Feb 07, 2011 11:52 am |
they were off a 2004 plate hdi
Posted: Mon Feb 07, 2011 12:00 pm |
Liam-HuTcH wrote: |
they were off a 2004 plate hdi |
then most likely you need the 266x22 disc, not the one in your link
Posted: Thu Feb 10, 2011 10:41 am |
Sorry for the hijack. How can you tell if you have Bosch or Lucas braking system?
Posted: Thu Feb 10, 2011 10:42 am |
Whats your VIN?
Posted: Thu Feb 10, 2011 10:58 am |
Lee wrote: |
Whats your VIN? |
pm'd
The reason I ask is I have a horrible grinding noise when I brake. Only happens for first half mile then goes. Sounds like coming from the back, and the handbrake is 10 clicks, which makes it sound like brake adjustment or worn shoes. Don't fancy stripping only to find I have to rebuild to go get some new shoes to come back and fit them. Might as well have them ready.
