Latest: SA01
Overall: 17138
Online Now [6972]:
Visitors: 6971
Today: 572483
Total: 111886617
Forums › The Car › 206 Problems › 206 GTI HDI FAP HELP !
Go to page Previous  1, 2
paulrushton
PostPosted: Mon Feb 07, 2011 3:06 pm Up
I've been doing a bit of research as I was tempted to buy the kit myself but doubt I'd recoup my spend back. On another forum I was reading you can do it. Apparently you need all the keys requiring coding and the car and Planet talks you through it. (apparently)!
Peugeot 206 GTI HDI Black
PostPosted: Mon Feb 07, 2011 3:10 pm Up
Not sure, I'll have to try and find out
Andy180+
PostPosted: Mon Feb 07, 2011 3:25 pm Up
coded many keys on planet and yeah it is a piece of cake. will only program virgin keys and not second hand ones. you need all the keys available and the transponder code, can get this from peugeot at a cost .
if you need any advise Lee give me a shout, i can talk you through it
paulrushton
PostPosted: Mon Feb 07, 2011 3:32 pm Up
I've got a brand new key, got the transponder code. All good to go!
Andy180+
PostPosted: Mon Feb 07, 2011 3:41 pm Up
will take 15 minutes tops on pps mate.
peterh
PostPosted: Tue Feb 08, 2011 4:01 am Up
hi,
thats great thanks for all the replies, pleased im not alone with the problem. I'm going to take the plunge and take it to the dealer to reset and force regen, i hope it doesnt need anything more as im almost financially drained after purchasing and fixing the problems so far. also since i changed the cap sensor Im struggling to get fuel in, ie it keeps cutting the pump off, I think it is to do with the rubber connector between the neck and tank which appeared to be far too long i may have it twisted, any one else had problems? thanks again. will let you know the out come.
peterh
peterh
PostPosted: Wed Feb 09, 2011 11:25 am Up
Hi all,
Just taken the car to have it plugged in to reset everything and been told that it has a fault in the glow plug circuit and therfore it will not regenerate as the glow plugs are used in the regeneration? aparently it needs to glow plugs at £60 before they can proceed? any one heard of this?
peterh
paulrushton
PostPosted: Wed Feb 09, 2011 11:36 am Up
Not heard if that. Usually only one or two glow plugs go so surprised all need replacing.
PostPosted: Wed Feb 09, 2011 11:37 am Up
yes, you will need to glowplug during regeneration.
during FAP regeneration, the filter will need higher exhuast gas temperature to burn off the soot.
turning on glow plug, by-pass intercooler...etc are one of the way to achieve this.
peterh
PostPosted: Mon Feb 14, 2011 11:28 am Up
Hi all,
just a quick update... I fitted the new glow plugs and took for a drive still the same unblock filter message. a friend then suggested a local garage may be able to help, a quick run to them and they plugged into it using snap on diagnostics which appears to be capable, (much to the operators surprise) to be able to reset everything and do regenerations. 30 mins on and the message was no more, the car runs better and on a 100 mile run yesterday returned 54 mpg and even showed 57 for a while. so touch wood... all is good.. just need to do a few more jobs, ie when i trapped the fuel hose into the tank when changing the sensor and now it takes 10 mins to put £20in, and also some clunking to investigate at the front os wheel, but all in all much happier thanks again for all the help...
peterh
gti-jack
PostPosted: Thu Feb 17, 2011 7:29 am Up
Hi,
I've been having a similar problem with mine, anti-pollution fault message. The codes were read at my local peugeot dealer, and the glow plugs need replacing as they are preventing regeneration.
peterh, did you mean all new glow plugs for £60? My peugeot dealer quoted £475 to replace my glow plugs as its supposedly a difficult job!
I didn't let them change the glowplugs, this was a couple of months ago and the (anti-pollution fault) message has come back now.
206 GTI HDI
peterh
PostPosted: Thu Feb 17, 2011 10:21 am Up
Hi,
Yes got all my glow plugs for £60 from a local motor factors, a handy friend of mine fitted them. since being plugged in and the faults clearing but i did only have the unblock filter message, all is well and the fuel economy is around 10mpg better. the only thing i now get is the occasional fan run on but im told that is still normal?
peterh
Squeaker
PostPosted: Wed May 04, 2011 12:34 pm Up
Seems the dodgy glow plugs are common in relation to this then as mine also need replacing.
Would love to know how bad they are to change as i'll be changing them myself Smile
PostPosted: Wed May 04, 2011 12:45 pm Up
took max. 10 mins to change it
Squeaker
PostPosted: Wed May 04, 2011 1:07 pm Up
Yeah but yours is 2.0 mine is 1.6, different engine. Are they in the same place?
Page 2 of 2
