Online Now [587]:
Visitors: 586
Today: 111716
Total: 157133484
Forums › The Car › 206 Problems › some info needed
some info needed
wull
PostPosted: Tue Feb 08, 2011 2:53 pm Up
right the verdict is in on what was up with the handling on the gti.
there is excessive play in the offside rear wheel.its terrible,it moves around as if someone is steering it.now all that was wrong with the front end was a ball joint and wheel bearing.
but is it easy to replace a rear bearing or is it a replacement axle job.the mechanic reckons that is the only option and i'm not entirely sure about this.
any info would be greatly appreciated peeps Very Happy
2000 gti
wull
PostPosted: Tue Feb 08, 2011 2:56 pm Up
or is it as simple as replacing the trailing arm????
2000 gti
