Latest: Andyblue64
Overall: 17123
Online Now [50]:
Visitors: 49
Today: 4953
Total: 98009058
Forums › The Car › 206 Problems › Erattic idle 2001 GTi - Solved
PostPosted: Wed Feb 09, 2011 5:51 am Up
Yeah, and a rubber O ring, I don't remember there being one on the old one.
Danny.
PostPosted: Wed Feb 09, 2011 6:18 am Up
Yea Hmm... strange i cant think of anythign else apart from air intake, or even exhaust blowing?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Wed Feb 09, 2011 6:25 am Up
But it wouldn't cause the car to cut out.
leigh_boy
PostPosted: Wed Feb 09, 2011 8:16 am Up
like i sai before sounds to me like Throttle Potentiometers its on the right hand side yellow and white plug, change that if you have a spare and should be sorted Smile
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Kersh
PostPosted: Wed Feb 09, 2011 8:18 am Up
he already did, its also called a throttle position sensor
Member number: 36
PostPosted: Wed Feb 09, 2011 8:25 am Up
Yep.
Just been home & got the cable for my phone.
Video is uploading now.
leigh_boy
PostPosted: Wed Feb 09, 2011 8:49 am Up
do you get any popping sounds \ backfires?
*DEAD*206 Gti 138
PostPosted: Wed Feb 09, 2011 8:51 am Up
No.
Here's the video.
s624.photobucket.com/a...EO0007.mp4
Its cut out by itself at the end.
leigh_boy
PostPosted: Wed Feb 09, 2011 9:14 am Up
seems like once its warmed up and comeing off the choke it dies, best thing to do is get te ecu checked for any stored fault codes. might give u a clue as to whats wrong
*DEAD*206 Gti 138
PostPosted: Wed Feb 09, 2011 9:20 am Up
I've got a code reader on its way to me in the post.
I'll get it plugged in.
Kersh
PostPosted: Wed Feb 09, 2011 9:21 am Up
206's dont have an automatic choke do they?
Member number: 36
leigh_boy
PostPosted: Wed Feb 09, 2011 9:24 am Up
its injection so ye Smile
the idle control valve will be part of the choke system, the rest is all ecu and injectors
*DEAD*206 Gti 138
PostPosted: Wed Feb 09, 2011 9:25 am Up
Yeah they do Kersh, the first min or so they idle 200RPM higher.
leigh_boy
PostPosted: Wed Feb 09, 2011 9:28 am Up
a test u can try is remove the idle controll valve, and leave cove the hole with your finger and sii if yu can get it to idle, or disconnec tthe idle control valve
*DEAD*206 Gti 138
PostPosted: Wed Feb 09, 2011 4:33 pm Up
Just unplug the idle control valve! Have you tested the fuel pressure?
Oily inlets are normal because the engine vents into the inlet. No point in cleaning it as it will just oil up again.
Page 3 of 5
