Latest: sparrowdclxvi
Overall: 17139
Online Now [375]:
Visitors: 374
Today: 36291
Total: 112424236
Forums › The Car › 206 Problems › long shot hope some one can help
charlie-52
PostPosted: Wed Feb 09, 2011 1:45 pm Up
basicly my girlfriend has a 2000 ford puma 1.7 we have just had a new water pump fitted once fitted heaters work fine now the car has sat over night there is no hot air comming from the heaters
any help will be appricated thanks Smile
MrrNoName
PostPosted: Wed Feb 09, 2011 1:47 pm Up
air lock?
Spanerman
PostPosted: Wed Feb 09, 2011 1:49 pm Up
Air lock or the heater control valve has packed in.
Does your interior light work?
If the fuse goes for the light the HCV gets no power and won't work
Sam.
Hello
dturbopeck
PostPosted: Wed Feb 09, 2011 1:55 pm Up
try running the engine with the coolant top off until the cooling fans kick in, if u hav no heaters now, u may hav a faulty heater control valve witch is in bulkhead
JamieM
PostPosted: Wed Feb 09, 2011 1:57 pm Up
Heater matrix.
It went on my old ZS and it's probably the same for this as they are made out of plastic iirc.
Aegean Blue 206 GTi180
MrrNoName
PostPosted: Wed Feb 09, 2011 2:00 pm Up
coincidence that it happens the day after a new water pump was fitted?
PostPosted: Wed Feb 09, 2011 2:34 pm Up
If it was working before the pump was replaced I reckon air lock.
gti180boy
PostPosted: Wed Feb 09, 2011 4:47 pm Up
If you just had the water pump changed why dont you take it back to where you had the work done??????????
Smile
180 Doctor
