Online Now [386]:
Visitors: 384
Bots: 2
Today: 94621
Total: 155964726
Forums › The Car › 206 Problems › squeak coming from rear
puggy206
PostPosted: Wed Feb 09, 2011 2:48 pm Up
i have developed a squeak at the offside rear of my 206 1.4 lx and at first i though it was my 6x9 speaker moving around (the screw had come loose) but i fixed this and the squeak continues, i have a funny idea it could be my suspension but it had been lowered by the previous owner and im not sure what springs he has used or how low it had been lowered, can anyway help solve this?
Citroen DS3
D-style +
1.6 VTI
benb
PostPosted: Wed Feb 09, 2011 2:52 pm Up
would be a torsion bar at the back
1.1lx 2000 plate
puggy206
PostPosted: Wed Feb 09, 2011 2:53 pm Up
is that a nice easy fix?
Citroen DS3
D-style +
1.6 VTI
benb
PostPosted: Wed Feb 09, 2011 2:54 pm Up
doubht it that maybe a wheel bearing or even exhaust give the wheel a woble when its off the ground and shake the exhaust a lil see if they make a noise
1.1lx 2000 plate
puggy206
PostPosted: Wed Feb 09, 2011 2:56 pm Up
its definatly the exhaust cause hat solid and ill try wobling the wheel when i can wat do u suppose i should do if it does wobble?
Citroen DS3
D-style +
1.6 VTI
puggy206
PostPosted: Wed Feb 09, 2011 2:58 pm Up
not the exhaust* and that*
Citroen DS3
D-style +
1.6 VTI
benb
PostPosted: Wed Feb 09, 2011 3:00 pm Up
well it will have bit of free play in it so take the wheel off there will be a large center bolt undo tht and take the front cover of the drum off there will be the bearings there should be a how to guide on this site
1.1lx 2000 plate
puggy206
PostPosted: Wed Feb 09, 2011 3:03 pm Up
ok cheers mate
Citroen DS3
D-style +
1.6 VTI
macj
PostPosted: Wed Feb 09, 2011 3:05 pm Up
Spray some lubricant on the rear seat back catches .... mine used to squeak before I stripped it all out and it did sound like it was from under the rear
-Dave-
PostPosted: Wed Feb 09, 2011 4:08 pm Up
Trade Rating: +36
Same here, Did my nut in for weeks before I found it.
Ex 206 Owner.
puggy206
PostPosted: Mon Feb 14, 2011 12:50 pm Up
yep you was right it was the back seats cheers guys
Citroen DS3
D-style +
1.6 VTI
