Latest: DanDan17
Overall: 17128
Online Now [56]:
Visitors: 55
Today: 27546
Total: 100455225
Forums › The Car › 206 Talk › Inlet Manifold Cleaning
Kersh
PostPosted: Wed Feb 09, 2011 4:17 pm Up
i definitely recommend this to everyone, this is the result from my 2001 GTi so i dread to think what some others are like!
basically i had to take my inlet manifold off whilst checking for an air leak, ran my finger around the inside of one of the tunnels and it came out covered in a black tar like substance all around the inside.
not only is this not good in any way for the engine, surely all that grot must restrict the air flow a great degree.
so, i dunked it in a tub of a strong solution of industrial degreaser/cleaner, i put a full 5 litres of the stuff in, probably dont need that much though.
left it there 24 hours then scrubbed the insides with a large pipe cleaning brush.
look at the water that was left over
that water was clear before.. and you can visibly see the scum floating on the top.
anyway i then rinsed it out THOROUGHLY and its now drying out overnight in the airing cupboard Smile
ill keep this thread updated with whether it makes any difference to the drive but im more than happy at the moment knowing that all that crap isnt going to be going through my engine!
definitely recommend it to anybody else
Member number: 36
DeadEyePaul
PostPosted: Wed Feb 09, 2011 4:43 pm Up
errrghhh! its as disgusting as my oven i cleaned recently
PostPosted: Wed Feb 09, 2011 4:54 pm Up
never do any house cleaning, will only do it the day before landlord came around lol
i suppose the manifold will get dirty very soon lol unless you got the oil catch tank.
JamieM
PostPosted: Wed Feb 09, 2011 8:11 pm Up
Nice lol
Aegean Blue 206 GTi180
MutilateTheDead
PostPosted: Thu Feb 10, 2011 8:01 am Up
Is this easy to do?
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
PostPosted: Thu Feb 10, 2011 8:03 am Up
Was a bit of a pain but got there in the end.
Had to remove the throttle body, wiring housing, fuel rail & injectors.
This is from the 206 I'm breaking, decided to take it off the failed engine before playing with the good one.
I'll swap it to the one on the other 206 tomorrow night and see if that works, the seals look alright on this one.
On the far right in this picture is a tiny bit of silver hose,
You need to unclip it for the intake manifold to come off.
Took me about 45 mins to remove, some bolts are a bit hard to reach.
Kersh
PostPosted: Thu Feb 10, 2011 8:07 am Up
What She Said
easy enough for anyone to do, dont have to be a mechanic or anything
Member number: 36
Quarmbo
PostPosted: Thu Feb 10, 2011 8:18 am Up
Are you expecting any gain from this?
Ford SportGay-A
MutilateTheDead
PostPosted: Thu Feb 10, 2011 8:20 am Up
I think just the knowledge of having a cleaner engine is nice Smile
Kersh
PostPosted: Thu Feb 10, 2011 8:24 am Up
nope, just good to know that its nice and clean down there
i love working on engines anyway so it was quite a nice little job, (bar the ten year old deposits)
cant do any harm once after 65k can it i suppose Smile
Member number: 36
bertt
PostPosted: Thu Feb 10, 2011 8:32 am Up
good post might give this ago miles are creeping up on mine so as you said wont do it any harm, give it a go when i service it
Kersh
PostPosted: Thu Feb 10, 2011 8:33 am Up
just allow time for it to soak and to dry out lol!
Member number: 36
