Posted: Thu Feb 10, 2011 4:06 am |
Edward wrote: |
Just unplug the idle control valve! Have you tested the fuel pressure?
Oily inlets are normal because the engine vents into the inlet. No point in cleaning it as it will just oil up again. |
Thats a good shout.
The fuel pump does sound a bit weak.
I'll see if I can test it this weekend.
Posted: Thu Feb 10, 2011 4:13 am |
Posted: Thu Feb 10, 2011 8:29 am |
Scanned it for faul codes got:
P0170 - Fuel Trim malfunction (Bank 1)
P0135 - 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0116 - Engine coolant Temp CKT Range/Performance
P0170P - ?
P0135P - ?
P0116P - ?
P0131P - 02 Sensor Circuit Low Volts (Bank 1 Sensor 1)
I'm not sure what the ones with the P at the end mean?
So what's the next step?
Posted: Thu Feb 10, 2011 8:34 am |
looks like you need a new lambda id say, atleast thats a couple of codes out the way
Posted: Thu Feb 10, 2011 8:50 am |
What about the 1st & 3rd code?
Posted: Thu Feb 10, 2011 9:25 am |
Did you say you replaced the Temp Sensor? What about the thermostat?
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Thu Feb 10, 2011 9:36 am |
Where is the thermostat located?
Posted: Thu Feb 10, 2011 9:40 am |
Dodgy thermostat wouldn't cause a fault code to pop up. If it was open the engine just wouldn't warm up so it would be in warm up mode all the time.
Posted: Thu Feb 10, 2011 9:49 am |
Edward wrote: |
Dodgy thermostat wouldn't cause a fault code to pop up. If it was open the engine just wouldn't warm up so it would be in warm up mode all the time. |
What do you think the first one is?
Something to do with the fuel pump?
Posted: Thu Feb 10, 2011 10:17 am |
Found out for you
The second P in the codes mean they are Pending.
Pending codes are soft codes, they are like a "heads up, something might be wrong" warning.
Posted: Thu Feb 10, 2011 10:20 am |
Lee wrote: |
Found out for you
Pending codes are soft codes, they are like a "heads up, something might be wrong" warning. |
So clearing them should sort it?
(And changing the 02 sensor)
What is "P0170 - Fuel Trim malfunction (Bank 1)" though?
Posted: Thu Feb 10, 2011 11:35 am |
Will be something to do with the mixture of the fuel/air, so if you have changed the lambda sensor it could have been taht at fault.
Posted: Thu Feb 10, 2011 11:42 am |
Lee wrote: |
Will be something to do with the mixture of the fuel/air, so if you have changed the lambda sensor it could have been taht at fault. |
Just done some Googling
Quote:: |
Any injection fault that affects the expected amount of fuel used will set a fuel trim code. It literally means that the Lambda probe [exhaust oxygen sensor] is asking for more fuelling adjustment than the ECU has the capacity to alter the pre-set programming. [I.e. It's ability to "trim" the settings.] |
I'll change the sensor this evening. Hopefully thats the end of it & I can sell the car!
Posted: Fri Feb 11, 2011 4:00 am |
put mine back on last night, doesnt really seem to have sorted the problem, i put it back with new seals and stuff so that means that its not an air leak..
does feel a bit smoother but thats probably because i cleared out all the crap.
what code reader was it that you bought chris??
Posted: Fri Feb 11, 2011 4:05 am |
I'm just borrowing it.
It's an OBDII scanner, I'm pretty sure it's this: cgi.ebay.co.uk/U480-OB...2a050e464e
I tried changing the lambda sensor but its seized, letting it soak in WD40 and I'll have another go this weekend.
