Latest: flipflap
Overall: 17140
Online Now [127]:
Visitors: 126
Today: 24596
Total: 113729711
Forums › The Car › 206 Problems › another problem with my misses puma! overheating now!
charlie-52
PostPosted: Thu Feb 10, 2011 4:50 pm Up
its recently had a new cambelt water pump and a heater control valve, after fitting the hcv today the heaters were blowing hot air
but half a mile down the road the temp gauge went into the red, when opening the expansion tank the temp gauge drops back down to half way this happens over and over again
if i leave the car running with the cap off the expansion tank my heaters dont blow hot air and my temp gauge dosnt move
help me please
fg-mart
PostPosted: Thu Feb 10, 2011 4:58 pm Up
air lock? leave the the cap off and let it idle for abit give it some revs. i might be wrong but give it a try
martyn
charlie-52
PostPosted: Thu Feb 10, 2011 5:01 pm Up
yea i tried that as soon as i put the cap back on and give it revs temp gauge goes up again
fg-mart
PostPosted: Thu Feb 10, 2011 5:03 pm Up
give it revs with the cap off mate . could be blocked
martyn
Quarmbo
PostPosted: Thu Feb 10, 2011 5:49 pm Up
If the system has been completely drained and new coolant added, it needs bleeding properly. Running with the cap off only really works when your topping up the coolant.
Ford SportGay-A
giveitsomebar
PostPosted: Thu Feb 10, 2011 6:18 pm Up
yeah it will be air locked if you dont know how to fix it a garage should be cheap enough as its a small job. fingers crossed it didnt get to hot an damage the headgasket!
fg-mart
PostPosted: Fri Feb 11, 2011 1:47 am Up
i might be wrong but that's what i did with the 2.5 v6 ford i had, i was told to do it as it could be blocked. just be prepared for coolant to poor out the expansion bottle.all i did was wrap some towels around it so it would soak all the coolant up that spilled out.
martyn
perry081064
PostPosted: Fri Feb 11, 2011 5:55 am Up
... just taken a 206 back to the dealer i had it from for doing this.
wasnt interested in what the cause was, i got them to exchange for another car
... been told its running again , but not for resale as theyre running it around with no thermostat in anymore Laughing Laughing
206 2.0 HDI
Spanerman
PostPosted: Fri Feb 11, 2011 6:25 am Up
I wouldn't suggest running it that hot!
There is a fault with the cooling system, most likely just needs bleeding Smile
Hello
