Latest: Mr-Koekwaus
Overall: 17125
Online Now [417]:
Visitors: 416
Today: 46552
Total: 99472040
Forums › The Car › 206 Problems › Fell over and landed on my key!!
Cubby
PostPosted: Fri Feb 11, 2011 4:05 am Up
Hi, the other day i fell over at work with my remote key in my pocket. After work i tried to unlock my doors but no joy. All the locks work fine when i use the key in the door. Took the key apart to inspect for damage but it all looks fine, then i changed the battery in it but still no luck. Ive tried following the re-programming post on here but im not getting it to work. Car is a 2005 gti 180 so i assume its multiplex re program that i should be following? Any ideas would be great, cheers
PostPosted: Fri Feb 11, 2011 4:09 am Up
You may have damaged the transponder chip in the key.
Cubby
PostPosted: Fri Feb 11, 2011 4:12 am Up
Do i have to get a new key?? Fell on it pretty hard, left a massive bruise on my leg
ukskater01
PostPosted: Fri Feb 11, 2011 5:09 am Up
Probly broke the print on the circuit board for the chip, if so it may be repairable depending if the board is layered or not.
The easiest option would be a new chip I'm afraid
leigh_boy
PostPosted: Fri Feb 11, 2011 5:14 am Up
The Transponder is not a board its a single chip if the transponda was broken the car would not start.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
