Posted: Wed Feb 09, 2011 7:41 am |
there is always a few set of drum or disc axle on ebay.
Posted: Wed Feb 09, 2011 7:48 am |
bellevuespares wrote: |
Massive Common Problem! Ive got list as long as my arm, Around 20 customers waiting on rear axle's
They sell like HOT CAKES |
knew i saw it somewhere
Posted: Wed Feb 09, 2011 7:49 am |
giveitsomebar wrote: |
knew i saw it somewhere |
because he has got a scrap yard
Posted: Wed Feb 09, 2011 1:43 pm |
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Wed Feb 09, 2011 3:30 pm |
PugJH wrote: |
would this fit mine then?
cgi.ebay.co.uk/PEUGEOT...588ba3fcd0
The whole van thing doesnt mean anythin, as its the same axle
Not that i've even seen a 1.1 van mind |
that is wheel bearing...i think you need the trailer arm bearing...?
Posted: Wed Feb 09, 2011 4:03 pm |
I am going to strip my rear axle and replace the bearings and fit a new uprated ARB..... Want me to do a "how to" on it?
Posted: Wed Feb 09, 2011 4:19 pm |
I think there's one to do the rear ARB (I did it) but I'm sure one for doing the axle bearings would be useful.
Posted: Thu Feb 10, 2011 12:35 pm |
I will strip it out in the next week or so.... if they need doing I will post it up
Posted: Thu Feb 10, 2011 3:02 pm |
Is it worth doing the mod with adding grease nipples while the beam is being overhauled?
The old boys on the French forum used to do it to rear beams before refitting them, reason why is so they can pump grease in with a grease gun to keep the bearings lubed.
Posted: Thu Feb 10, 2011 4:02 pm |
I was told of this mod by my local dealership parts man.... old school parts dept..... I will include it
Posted: Thu Feb 10, 2011 4:10 pm |
i don't quite understand this?
do you mean put the grease nipple on the trailing arm? how can you force the grease into the bearing then?
Posted: Thu Feb 10, 2011 4:21 pm |
keep your eye on the "how to"
Posted: Thu Feb 10, 2011 4:30 pm |
macj wrote: |
keep your eye on the "how to" |
Posted: Fri Feb 11, 2011 3:37 am |
a how to for the trailing amr would be great if thats what needs doin on mine
Beauté Noire | |
Posted: Fri Feb 11, 2011 7:36 am |
I wouldn't bother with the grease nipples.
