Online Now [520]:
Visitors: 519
Today: 106644
Total: 157128462
Forums › The Car › 206 Problems › Radio Control Stalk Problem
A18NHH
PostPosted: Sat Feb 12, 2011 9:16 am Up
Hi all,
the 'wheel' on my radio control stalk doesn't work as it should, sometimes it doesn't work, other times i scroll it one way and it changes the radio station in the wrong dircetion Shocked
Can i just replace the radio stalk and this will fix the problem? or do i need to replace all of the stalks? (indicators etc...)
Wahoo!
PostPosted: Sat Feb 12, 2011 9:35 am Up
Its only clipped in.
Are you sure its fully pushed home as the radio stalk can come loose?
There less then £16 brand new including VAT from any Peugeot / Citroen main dealer if you need a new one.
A18NHH
PostPosted: Sat Feb 12, 2011 10:48 am Up
there's barely any movement in it but i've tried pushing it in as much as i can but still have the same problem.
What do i have to do to remove it?
Wahoo!
PostPosted: Sat Feb 12, 2011 11:28 am Up
2 x torx 20 screws to drop the bottom steering column plastic trim off, lift the top trim of.
Press the clip on the back of the radio stalk & slide it out the com2000 unit.
