Posted: Mon Feb 14, 2011 1:24 pm |
as title, i had the radio off and noticed when i was parking and turned the steering wheel there was a 'clunk'
not too loud but enough to know it isn't right - i only seems to be noticable at low speeds though
any ideas? its a 206 GTi 2002
Posted: Mon Feb 14, 2011 1:32 pm |
onI have the same problem on my 180 mate. Was told it was the drive shaft joints knackered but when it went to the garage, they said there was nothing wrong with them. Still dont know what the noise is. Am guessing it can only be the steering rack.
| They could of made it 200bhp!! | |
Posted: Mon Feb 14, 2011 1:34 pm |
If it does it stood still could look into topmount bearings
Posted: Mon Feb 14, 2011 1:38 pm |
yeah top mounts, i had this not long ago.
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
it does do it when stood still
Posted: Mon Feb 14, 2011 1:42 pm |
check the spring on each front side havnt snapped.
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Mon Feb 14, 2011 2:06 pm |
Trade Rating: +45
will either be top mount bearing or the droplinks, both quite a cheap fix if i remeber correctly
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Mon Feb 14, 2011 2:07 pm |
good
i changed to drop links not long ago so i'll check they are tight and okay - failing that i'll do top mount bearing - thank god both only look like a £20 parts jobb
Posted: Mon Feb 14, 2011 2:12 pm |
can you change just the bearing or do you need to change the whole top mount?
Posted: Mon Feb 14, 2011 2:54 pm |
| A18NHH wrote: |
| can you change just the bearing or do you need to change the whole top mount? |
Can change just the bearings on there own.
Posted: Sat Mar 19, 2011 5:01 pm |
for information it was the top mount bearing - now repired
£45 labour and £10 part
Posted: Sat Mar 19, 2011 6:52 pm |
Glad it's sorted
Posted: Sat Mar 19, 2011 7:18 pm |
lol
don't use cheap top mount bearing..... i manage to destroy 2 set of cheap top mount bearing in 3 months.....
peugeot top mount bearing is the only way to go
