Latest: DanDan17
Overall: 17128
Online Now [53]:
Visitors: 52
Today: 11395
Total: 100572115
Forums › The Car › 206 Talk › how can you tell when turbo is going ?
PostPosted: Mon Feb 14, 2011 2:53 pm Up
eddrj wrote:
It goes well and can hear it the same so you think its alrit ?
surely going or gone one wouldnt pull same or hear it the same ?
Check the pipes sorry for being stupid i duno where it is lol i dont know about these things
Follow the pipe from the airbox you will reach the turbo, then pipe goes from turbo into engine. Remove the pipe and check for oil in them. (big black plastic pipe)
eddrj
PostPosted: Mon Feb 14, 2011 2:56 pm Up
ok thanks , so hopefully will just be the pipe ? that wouldnt be much or hard to fix would it ?
Old car 2000/ 206 2.0 hdi.
PostPosted: Mon Feb 14, 2011 3:01 pm Up
Could have a leak that would make a noise, but checking the pipes for oil is a good place to start, oil in the pipes might give you a good indication turbo maybe on its way out.
eddrj
PostPosted: Mon Feb 14, 2011 3:03 pm Up
holy s**t thinking bout it when i changed the whole airbox that big pipe at bottom did have a split in it lol is that all it is ? how hard are these to change ? cheap job ?
PostPosted: Mon Feb 14, 2011 3:07 pm Up
A split pipe would make a noise, I know it would as mine currently has a split in it now and makes a racket.
Mines cracked just befor turbo.
Take a look and if you can tape it up see if it helps. Get a new pipe when you can.
eddrj
PostPosted: Mon Feb 14, 2011 3:08 pm Up
alrit thanks whats thats pipe called ? you know how much they are ? il tape it up to see if that helps and see how long that lasts.
cheers.
PostPosted: Mon Feb 14, 2011 3:12 pm Up
Ummm if its the same pipe we are both on about would be called air intake pipe I would think, there is one before and one after the turbo.
MrrNoName
split pipe gives more of a rasp then a whine, split will make a noise though usually Razz
eddrj
PostPosted: Mon Feb 14, 2011 3:14 pm Up
ok cool cheers mate. yeah does sound tha same
big black pipe at bottom under the airbox .Looks like good news ive seen the big split in pipe thats probably all it is so dont need new turbo. Very Happy
PostPosted: Mon Feb 14, 2011 3:16 pm Up
big black pipe at bottom under the airbox .Looks like good news ive seen the big split in pipe thats probably all it it is so dont need new turbo. Very Happy
tape it up will do the job. or you can even remove it.
MrrNoName
thats good news, as said before lol
"hissey noise, like rasping? probs a split pipe."
eddrj
ok cheers guys il tape it up best i can in next few days asap if it fixes it im happy and sorted.
Guna need some strong tape now.
adam_16v
PostPosted: Mon Feb 14, 2011 3:48 pm Up
Mine makes a noise when coming off the accelerator, like a rasping. Actually sounds like my mates leon with a recirc valve?? Possible split pipe?
a
eddrj
PostPosted: Wed Feb 16, 2011 5:21 am Up
thats weird noise is stopped cant hear it anymore
didnt do anything to it either .
MrrNoName
PostPosted: Wed Feb 16, 2011 5:23 am Up
oddly enough, sometimes the threat to actually fix a problem is enough to make it dissapear lol Very Happy
Page 2 of 3
