Posted: Mon Feb 14, 2011 2:53 pm |
eddrj wrote: |
It goes well and can hear it the same so you think its alrit ?
surely going or gone one wouldnt pull same or hear it the same ?
Check the pipes sorry for being stupid i duno where it is lol i dont know about these things |
Follow the pipe from the airbox you will reach the turbo, then pipe goes from turbo into engine. Remove the pipe and check for oil in them. (big black plastic pipe)
Posted: Mon Feb 14, 2011 2:56 pm |
ok thanks , so hopefully will just be the pipe ? that wouldnt be much or hard to fix would it ?
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Mon Feb 14, 2011 3:01 pm |
Could have a leak that would make a noise, but checking the pipes for oil is a good place to start, oil in the pipes might give you a good indication turbo maybe on its way out.
Posted: Mon Feb 14, 2011 3:03 pm |
holy s**t thinking bout it when i changed the whole airbox that big pipe at bottom did have a split in it lol is that all it is ? how hard are these to change ? cheap job ?
Posted: Mon Feb 14, 2011 3:07 pm |
A split pipe would make a noise, I know it would as mine currently has a split in it now and makes a racket.
Mines cracked just befor turbo.
Take a look and if you can tape it up see if it helps. Get a new pipe when you can.
Posted: Mon Feb 14, 2011 3:08 pm |
alrit thanks whats thats pipe called ? you know how much they are ? il tape it up to see if that helps and see how long that lasts.
cheers.
Posted: Mon Feb 14, 2011 3:12 pm |
Ummm if its the same pipe we are both on about would be called air intake pipe I would think, there is one before and one after the turbo.
split pipe gives more of a rasp then a whine, split will make a noise though usually
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Mon Feb 14, 2011 3:14 pm |
ok cool cheers mate. yeah does sound tha same
big black pipe at bottom under the airbox .Looks like good news ive seen the big split in pipe thats probably all it is so dont need new turbo.
Posted: Mon Feb 14, 2011 3:16 pm |
eddrj wrote: |
big black pipe at bottom under the airbox .Looks like good news ive seen the big split in pipe thats probably all it it is so dont need new turbo. |
tape it up will do the job. or you can even remove it.
thats good news, as said before lol
"hissey noise, like rasping? probs a split pipe."
ok cheers guys il tape it up best i can in next few days asap if it fixes it im happy and sorted.
Guna need some strong tape now.
Posted: Mon Feb 14, 2011 3:48 pm |
Mine makes a noise when coming off the accelerator, like a rasping. Actually sounds like my mates leon with a recirc valve?? Possible split pipe?
Posted: Wed Feb 16, 2011 5:21 am |
thats weird noise is stopped cant hear it anymore
didnt do anything to it either .
Posted: Wed Feb 16, 2011 5:23 am |
oddly enough, sometimes the threat to actually fix a problem is enough to make it dissapear lol
