Latest: dreyfalon
Overall: 17121
Online Now [567]:
Visitors: 566
Today: 62565
Total: 97588865
Forums › The Car › 206 Talk › GTI ECU question
GTI ECU question
leigh_boy
PostPosted: Tue Feb 15, 2011 6:32 am Up
if the ecu is up the swanny, and needs to be replaced.
what other parts need to be replaced with it?
to my understanding i would need
1. ecu
2. transponder ring
3. transponder from the key
4. BSI unit
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Tue Feb 15, 2011 6:35 am Up
ECU & get it coded to the car.
OR
Send your original ecu away for test / repair.
www.bba-reman.com/uk/index.aspx
leigh_boy
PostPosted: Tue Feb 15, 2011 6:42 am Up
I already know it failing Sad i can get the 4 bits i mentioned for £140
i could get an ecu how much does it normaly cost and time involved to do it?
*DEAD*206 Gti 138
PostPosted: Tue Feb 15, 2011 6:58 am Up
I have the ecu, bsi and transponder ring (but not the key) that I'm selling for far less than that. Is the transponder ring useless without the one from the key?
PostPosted: Tue Feb 15, 2011 7:43 am Up
Transponder aerial / ring are NOT coded on the 206.
The only time you need to change one is when it stops working Laughing
leigh_boy
PostPosted: Tue Feb 15, 2011 8:20 am Up
so harry in awnser to your question its useless with out the tranponda chip from the key as thats coded to the ecu \ bsi your best bet is to just sell the ecu for recodeing. witch i dont think i can be assed to go down that route id rather just stick a new load of bits in and have spares Smile
*DEAD*206 Gti 138
PostPosted: Tue Feb 15, 2011 8:40 am Up
I see, yeah I guess. I may just bundle it onto it ebay and persume the buyer knows what he's doing with it
leigh_boy
PostPosted: Wed Feb 16, 2011 10:42 am Up
Just a quick thought
if i change the ecu , bsi and put the transponder in my current key so i dont have to change the locks,
will the central locking still work from the key?
and will the alarm, imobilisa still work?
i would i need to change all the locks and keys to match the ecu \ get them all recoded?
*DEAD*206 Gti 138
leigh_boy
PostPosted: Wed Feb 16, 2011 10:44 am Up
incase it matters
my cars on a V but could be 99 or 2000
not sure if its pre plex or multi plex or how to tell
and i have a 2 button key
*DEAD*206 Gti 138
PostPosted: Wed Feb 16, 2011 12:34 pm Up
Harry, tell me the VIN number of the car and I'll get you the immobilser code, then the buyer would just have to get a new key and get the keys coded.
If you change the transponder into the new key, then yes the car should still start. You may have to resync it tho.
V reg is non-plexed
bellevuespares
PostPosted: Wed Feb 16, 2011 7:09 pm Up
I have a full kit if still needed Smile
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
