Latest: DanDan17
Overall: 17128
Online Now [61]:
Visitors: 60
Today: 46683
Total: 100474342
Forums › The Car › 206 Problems › 206 tempertaure gauge jumping
00budham00
PostPosted: Thu Feb 17, 2011 4:27 am Up
the gauge is jumping but engine pipes are cool!
i hear it a earth maybe?
where can i locate this earth brade wire?
or your thoughts it is not this maybe something else ?
cheers guys n girls
Antknee
PostPosted: Thu Feb 17, 2011 4:31 am Up
there's loads of people with this problem recently :/ must be the weather. but anyway i had it too so changed the temp sensor (green plug one) and haven't had it come back since, might be worth doing that, not sure about the earth though
Antknee
PostPosted: Thu Feb 17, 2011 4:48 am Up
That would probably be the one you'd need it you did change it, but i'd double check first cgi.ebay.co.uk/206-Tem..._941wt_803
myke
PostPosted: Thu Feb 17, 2011 4:57 am Up
I had the same problem a while back but it's stopped now. Once I've got a couple of quid I'm going to change the sensor.
I posted a thread about sensors here which might come in handy:
206info.co.uk/Forums/v...24059.html
There's this one that's 12 quid:
www.eurocarparts.com/e...9a3b3&ENTS
But not sure if it'd be the same for your car... have a look through the thread I put a link to, it might help Smile
00budham00
PostPosted: Thu Feb 17, 2011 10:58 am Up
where is the sensor located ?
