Latest: SA01
Overall: 17138
Online Now [103]:
Visitors: 102
Today: 39732
Total: 112209585
Forums › The Car › 206 Talk › Coilovers
Coilovers
Lee180
PostPosted: Thu Feb 17, 2011 12:00 pm Up
just been flicking through coilovers for the 180, was debating getting some D2 racing coilovers. any suggestions ?
Originate, don't duplicate.
PostPosted: Thu Feb 17, 2011 12:03 pm Up
Only get coilovers if you are going stupidly low or adjusting the ride height a lot. Otherwise, get springs.
Lee180
PostPosted: Thu Feb 17, 2011 12:07 pm Up
iv had, coilovers and springs, the coilovers seemed to improve the handling alot better.
both lowered the same amount
Icetto
Do you have a budget Lee180?
Lee180
PostPosted: Thu Feb 17, 2011 12:09 pm Up
i never skimp out on handling or breaking Wink
00budham00
i love my coilovers i near enough change the ride hight every week !!! i love it and its so easy
always have a can of wd40 to hand to help get the dirt from threads
Uz
PostPosted: Thu Feb 17, 2011 12:14 pm Up
If you've got the money go with Billie, Eibach or AST coilovers.
www.larkspeed.com/inde...22&a=i Very Happy
Lee180
PostPosted: Thu Feb 17, 2011 12:15 pm Up
Cheers howey
PostPosted: Thu Feb 17, 2011 12:16 pm Up
Brilliant coilovers! Wish I could afford some Sad
Icetto
PostPosted: Thu Feb 17, 2011 12:17 pm Up
Well if budget is not a problem then look at the Tein range. I think they have electronically adjustable ones that you can change height by sitting in your car
Lee180
PostPosted: Thu Feb 17, 2011 12:18 pm Up
i personally think thats a tad over engineering on a 206 lol
PostPosted: Thu Feb 17, 2011 1:05 pm Up
The coilovers must have been a different spring or damper rate then.
A damper with spring and a coilover of the same rate will behave identically.
PostPosted: Thu Feb 17, 2011 1:32 pm Up
why D2? do you know D2 is well over price? D2 is actually made in taiwan.
and also, tein don't do electronically adjustable dampers for 206. r at least not off the shelf
not to mention tein is also just another brand of "cheap" taiwan coilovers, the lowest spec coilovers are twin-tube as well.
PostPosted: Thu Feb 17, 2011 1:33 pm Up
and basically you can convert standard dampers to coilovers easily Laughing
