Latest: Worthy967
Overall: 17143
Online Now [505]:
Visitors: 504
Today: 14528
Total: 115659193
Forums › The Car › 206 Problems › indicator flashing fast when i apply brakes
scottbear75
PostPosted: Thu Feb 17, 2011 5:42 pm Up
hi
help needed when im indicating to go left my indicator goes ok, when i press the brake it starts to go faster ,as soon as i release the brake it goes back to normal.
i have checked my brake lights, all lights working ok , so dont know whats wrong with it. (206 sw 03)
head gasket case
PostPosted: Thu Feb 17, 2011 5:43 pm Up
Dodgey wiring in the rear cluster by the sounds of it. Could be a earthing problem, or water got into the electrics.
Does the rear indicator go out, when you press the brakes?
scottbear75
PostPosted: Thu Feb 17, 2011 5:44 pm Up
no mate indicator light stays on
head gasket case
PostPosted: Thu Feb 17, 2011 5:50 pm Up
Make sure all the connections are sound.
Try softbooting the BSi as well
scottbear75
PostPosted: Thu Feb 17, 2011 6:42 pm Up
will do .
thanks
head gasket case
Rob2859
PostPosted: Thu Feb 17, 2011 9:15 pm Up
have you changed the bulb recently?
scottbear75
PostPosted: Fri Feb 18, 2011 10:55 am Up
no mate havent touched a thing
head gasket case
