Online Now [333]:
Visitors: 332
Today: 45297
Total: 105939315
Forums › The Car › 206 Problems › Coilovers Bang over bumps
M0j0
PostPosted: Thu Feb 17, 2011 5:12 pm Up
Hi all I've fitted some coilovers and the ride is terrible even over little bumps it feels/sounds like there isnt any suspension just the wheel hitting the floor at full pelt, Theve got new top mounts / bearings and also new drop links when fitted.
The helper springs were removed to begin with but i've refitted them and its abit better but not 100%
Think i might sell them and get springs / shocks
Anyone got any other ideas or are all coilovers like this on a 206?
Cheers
Chris
2003 '53' Quicksilver HDI SW - Lowered, Exhaust, Intercooler & Remap soon Very Happy
dturbopeck
PostPosted: Thu Feb 17, 2011 5:15 pm Up
are they new? sounds like there bottoming out.
PostPosted: Thu Feb 17, 2011 5:16 pm Up
What make are they?
And how low?
If there cheap coilovers it's nothing to be surprised about IMO
I have had cheap and did just the same, have read other stories the same too
M0j0
PostPosted: Thu Feb 17, 2011 5:45 pm Up
Thankyou for the reply indeed there new cheapo's off ebay who knows what make? (should of read up before buying them)
There lowered about 60-70mm?
Its just the worse noise ever when it hits a bump and it feels like the whole front ends not attached
PostPosted: Thu Feb 17, 2011 5:47 pm Up
Buy cheap, buy twice.
PostPosted: Thu Feb 17, 2011 6:19 pm Up
my coilovers work like sweat Razz
back to your questions.
is probably because you drop your car too low. not enough travel for the spring and dampers-> bottom out.
in theroy you can drop 100mm or a bit more but none of those mid-range coilovers are design to handle that kind of drop.
PostPosted: Fri Feb 18, 2011 1:29 am Up
Mine bangs and knocks now and again... but only since i've taken the helpers out and its all the way down Laughing
Mine are ebay budget jobbies and until i slammed it and it was 60mm(ish) it never made any noises they aren't always crap cause they're cheap
PostPosted: Fri Feb 18, 2011 1:56 am Up
Did the bump stops get fitted?
kamracing
PostPosted: Fri Feb 18, 2011 4:53 am Up
a lot of the cheap coilover kits have a tendency to go coil bound which is basically the spring fully compressing so you have no spring travel left. It could be this or the damper bottoming out..
www.kamracing.co.uk / www.cl-brakes.co.uk
