Latest: sparrowdclxvi
Overall: 17139
Online Now [106]:
Visitors: 105
Today: 13830
Total: 112640430
Forums › The Car › 206 Problems › Not Starting
Not Starting
CeeBee206
PostPosted: Fri Feb 18, 2011 9:12 am Up
Hiya, this is my first post. My battery went totally flat. When we tried to jump start, the engine spins over o.k. but will not fire. The Engine Diagnostics Amber light is on but I am not sure if that stays on until it fires up. It seems as if the immobaliser is staying on. Is there something that needs doing after having a totally flat battery before it will fire up.
Thanks for any help.
Christina. X Crying or Very sad
206 1.4 LX Full Leather.
PostPosted: Fri Feb 18, 2011 10:50 am Up
What year is it?
<02 make sure the fuel inertia switch hasnt activated (button near the battery)
>02 try rebooting the BSI [click my signature for details]
Big_Rich180
PostPosted: Fri Feb 18, 2011 10:54 am Up
Could it be that the battery is just dead??
Buy a new on and try again.
EDIT: Scrap that, it cant be if the car turns over..
Lee180
PostPosted: Fri Feb 18, 2011 10:56 am Up
check the fule cut of switch, mine used to do it when going over potholes.
Originate, don't duplicate.
CeeBee206
PostPosted: Fri Feb 18, 2011 2:50 pm Up
Hi Lee, its a 2000 on a "w". I've tried charging the battery on a new battery charger and the fuse in the charger blew as soon as it was switched on. Knackered ?? ( the battery not the charger ) It puzzles me because I managed to turn it over fairly quickly with jump leads on. If I put a New Battery on it should hopefully be o.k. ?
Thanks Christina X
