Online Now [112]:
Visitors: 111
Today: 68867
Total: 117632426
Forums › The Car › 206 Problems › performance
performance
puggy206
PostPosted: Fri Feb 18, 2011 11:35 am Up
My 206 1.4 has been losing its get up an go alot recently, like in two days its gone from a pretty quick accerlating car (i know its not the best but still pretty good) to quite slow and the throttle response has just dissappeared i put my foot down and nothing happens (compared to its normal self) and in some casses when i put my foot down the car feels like its struggling (im in the right gear and right revs for power, it just doesnt seem to wanna work)
Any suggestions as what could be wrong seeing as this problem seems to have come overnight
Citroen DS3
D-style +
1.6 VTI
Lee180
PostPosted: Fri Feb 18, 2011 11:37 am Up
buy a 180 Wink
Originate, don't duplicate.
puggy206
knew u would have something to say Wink
Citroen DS3
D-style +
1.6 VTI
Lee180
PostPosted: Fri Feb 18, 2011 11:39 am Up
haha (: fule filter ?
puggy206
had one like less then 2000 miles ago
Citroen DS3
D-style +
1.6 VTI
Lee180
PostPosted: Fri Feb 18, 2011 11:42 am Up
sucking in warm air Wink proper service ?
puggy206
PostPosted: Fri Feb 18, 2011 11:43 am Up
had a full proper service Smile
Citroen DS3
D-style +
1.6 VTI
puggy206
PostPosted: Fri Feb 18, 2011 11:44 am Up
and as for sucking in warm air the problems there with a cold or hot engine
Citroen DS3
D-style +
1.6 VTI
NICKST
PostPosted: Fri Feb 18, 2011 12:23 pm Up
When it was Serviced did they use ngk plugs?
Jay794
PostPosted: Fri Feb 18, 2011 1:42 pm Up
Could be dirty fuel you are putting in
PostPosted: Fri Feb 18, 2011 1:55 pm Up
Run on V Power for a couple of weeks, clean the air filter and see how it goes Smile
puggy206
PostPosted: Fri Feb 18, 2011 1:58 pm Up
NGK plugs and telco fuel I have a k&n filter on it.
Citroen DS3
D-style +
1.6 VTI
NICKST
PostPosted: Fri Feb 18, 2011 2:02 pm Up
Take out the ngk plugs and replace with bosh super 4 my 180 ran like a 1.1 with ngk plugs isn't it. It's known that pugs don't like ngk plugs sure some one else. Will confirm this.
PostPosted: Fri Feb 18, 2011 2:14 pm Up
:whathesaid:,NGK are bad for pugs,cause missfiring and lot of problems,start from the plugs,and see how it goes
D4NTP
PostPosted: Fri Feb 18, 2011 2:15 pm Up
Can't confirm the plug theory actually, mine runs like a dream on NGK R plugs. nice and brown. Mine felt dead sluggish the other week but that was due to cleaning and re-oiling the filter....a bit excessively. Have they cleaned the filter at the service and over oiled it? If your getting excessive air in their that could slow things down a bit...check for leaks. Unlikely to be anything big if its only just come on over the past few days. Most likely something you have played about with.
