Latest: heikkisj
Overall: 17126
Online Now [57]:
Visitors: 56
Today: 12429
Total: 100385165
Forums › The Car › 206 Talk › oh thats all i need
oh thats all i need
stevedude
PostPosted: Sat Feb 19, 2011 9:48 am Up
just looked at online MOT
Advisory Notice issued
Offside Side repeater slightly discoloured (1.4.A.2d)
Front Brake pad(s) wearing thin (3.5.1f) passenger side done now
Brake load sensing valve linkage stiff (3.6.E.4)
Brake valve corroded but not excessively weakened (3.6.E.1b)
Nearside Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.3) now fixed
Offside Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.3)
Nearside door mirror being held together with tape.
Both front tyres getting near to wear indicators.
Wear and corrsion on front brake discs. passenger side done
i got pads and discs, got n/s wishbone.
not sure what/where brake valve is?
not sure what/where brake load sensing valve linkage?
oh the joys of having a car
Happydays
Mrs_Howey
PostPosted: Sat Feb 19, 2011 9:50 am Up
The brake load sensing valve is on the rear axle on the drivers side, just need wd40 and wiggle it with a screwdriver it should free up Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
stevedude
PostPosted: Sat Feb 19, 2011 9:54 am Up
whats she look like?
is the brake valve the thingy inside the drum, got a leak from where the pipe goes into drum
Happydays
PostPosted: Sat Feb 19, 2011 9:56 am Up
Stick your head under the car & look at the rear beam near the area in front of the drivers rear wheel, you will see a small square shaped valve with pipes coming from it, that's what your looking for.
PostPosted: Sat Feb 19, 2011 10:06 am Up
How do you now some of them haven't been changed?
Most is just general wear and tear
stevedude
PostPosted: Sat Feb 19, 2011 3:55 pm Up
ive looked, discs has got large lip on, pads waffer thin, wishbone mount is split, tires are low on tread, ill check valve thingy tomoz, now i know where it is lol, thanks mrBSI for that.
Happydays
pug206lx
PostPosted: Sat Feb 19, 2011 7:39 pm Up
Sounds like a very picky MOT tester
stevedude
PostPosted: Sun Feb 20, 2011 11:27 am Up
im lost mate lol?
Happydays
Rob2859
PostPosted: Sun Feb 20, 2011 12:16 pm Up
stevedude wrote:
im lost mate lol?
I have a map. £15 posted.
