Posted: Sat Feb 19, 2011 2:30 pm |
my 03 plate 206 sounds as if one of the front wheel bearings is going, are these pressed on?
so in other words, is it a garage job?
Posted: Sat Feb 19, 2011 2:33 pm |
yes, the are press on
Posted: Sat Feb 19, 2011 2:34 pm |
cheers, thought as much
Posted: Sat Feb 19, 2011 2:49 pm |
they are pressed on mate but if u can get your old one out u can freeze your new bearing n it will go in bit more time consuming but will save money(old school trick from my dads mechanic days)
Posted: Sat Feb 19, 2011 2:58 pm |
Trade Rating: +13
If you get the hub off, a garage should be able to press the old out and new in for a tenner.
Remember some places charge 1hr minimum, so back street garages maybe a better option.
Posted: Sat Feb 19, 2011 2:59 pm |
When you say freeze is that actually in the freezer? I can see how it'll work.
| Peugeot 206 GTI HDI Black | |
Posted: Sat Feb 19, 2011 3:05 pm |
paulrushton wrote: |
When you say freeze is that actually in the freezer? I can see how it'll work. |
Yeah it works as the metal casing contracts as its cold so is very slightly smaller.
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Sat Feb 19, 2011 5:25 pm |
Boywonder7 wrote: |
they are pressed on mate but if u can get your old one out u can freeze your new bearing n it will go in bit more time consuming but will save money(old school trick from my dads mechanic days) |
nice trick
Posted: Sun Feb 20, 2011 1:41 pm |
iv done both my front wheel bearings this way because my work was closed for 3 weeks for holidays and iv not had problem with either of them
Posted: Sun Feb 20, 2011 3:22 pm |
maybe the old one could be taken out a little easier by using that computer keyboard spray but upside down so liquid comes out?
Posted: Mon Feb 21, 2011 5:11 am |
Boywonder7 wrote: |
does that mean i'll have to defrost all my chips lol
cheers for the tip, i'll see what happens
