Latest: sparrowdclxvi
Overall: 17139
Online Now [81]:
Visitors: 80
Today: 25248
Total: 113300210
Forums › The Car › 206 Problems › Blower Motor Fault
Blower Motor Fault
SteveM
PostPosted: Sat Feb 19, 2011 3:56 pm Up
Had the shock of my life earlier as my dash started making a nasty noise while I was driving along the ring road.
I have established the fault must be the blower motor for the hot/cold air inside the car cabin. I think this is the problem as when I turn the fan to '0' there is no noise and it gets louder as I turn the fan on ('1') and then up to settings 2 and 3. It works on all settings so I dont think its the resistor?!
The noise itself is like a whirring noise, it sounds like a fan spinning round but with something in it if that makes sense.
So, my problem is......
1.) Is this common?
2.) How do I get the motor out?
3.) Is it possible to clean it out or does it sound like its buggered?
Thanks in advance.
206 2.0 D Turbo (V)
eddrj
PostPosted: Sat Feb 19, 2011 4:00 pm Up
i have same probably makes weird horrible noise on 1, 2 n sometimes 3 too
anyone know how to sort this ??
Old car 2000/ 206 2.0 hdi.
bertt
PostPosted: Sat Feb 19, 2011 5:13 pm Up
i had this on mine and it eventually failedm was the screws holding the motor in had come loose and it was rubbing on the housing, maybe the same it sounds it from what your describing as thats what mine was like
SteveM
PostPosted: Sat Feb 19, 2011 6:22 pm Up
How did you get to it and how did you get the motor out to check???
206 2.0 D Turbo (V)
bertt
PostPosted: Sat Feb 19, 2011 6:35 pm Up
take the glovebox out and reach around the back youl be able to feel it and if its loose will wobble around
Rob2859
PostPosted: Sat Feb 19, 2011 8:07 pm Up
fine sounds like a CD spinning on number 1
SteveM
PostPosted: Sun Feb 20, 2011 4:13 pm Up
Sorted, there was a leaf in the blower motor. Only took 30 minutes too.
206 2.0 D Turbo (V)
