Posted: Sat Feb 19, 2011 2:33 pm |
hi was wondering if the 106 1.3 rallye head will fit onto the 206 1.4 lx to give a bit more performance
thanks
Posted: Sat Feb 19, 2011 2:42 pm |
will fit (i presume yours is 8v?). but you might need the inlet manifold as well.
and you will need a remap.
Posted: Sat Feb 19, 2011 2:48 pm |
Depends which years yours is made
Pre 2000 yes
Otherwise you will need new inlet, and dont forget you will need a remap to run it right
Port the head, simpler (or invest in a 1.6 inlet manifold and ported throttle body)
| Team Impossible Possible
Posted: Sat Feb 19, 2011 2:50 pm |
| Addaz wrote: |
Pre 2000 yes
Port the head, simpler (or invest in a 1.6 inlet manifold and ported throttle body) |
but the valves in the rallye head is bigger, not to mention the cam too.
Posted: Sat Feb 19, 2011 2:55 pm |
| Seabook wrote: |
| Addaz wrote: |
Pre 2000 yes
but the valves in the rallye head is bigger, not to mention the cam too. |
To cope with the 1.3 METAL inlet, so surely with the 1.4 inlet it will choke it
And there is no ifs or buts you need a remap with a 1.3 inlet manifold, lots of people have had running problems with this mod
Posted: Sat Feb 19, 2011 2:57 pm |
so it should fit then my 206 is a 2001 on a y plate well am hoping to be buying the engine tomorow and have been told it has a fancy aluminium inlet manifold on it not sure if that will make a difference to it
thanks
Posted: Sat Feb 19, 2011 2:59 pm |
| wraxer69 wrote: |
so it should fit then well am hoping to be buying the engine tomorow and have been told it has a fancy aluminium inlet manifold on it not sure if that will make a difference to it
thanks |
Yes it will, but we said before
You will more than likely need a live mapping session costing around the £500 mark
Posted: Sat Feb 19, 2011 3:00 pm |
ats more than a payed for the car lol if a don't remap it straight away will it wreck the engine
Posted: Sat Feb 19, 2011 3:01 pm |
| wraxer69 wrote: |
| ats more than a payed for the car lol if a don't remap it straight away will it wreck the engine |
No it just wont run correctly
Might do though, your choice
Posted: Sat Feb 19, 2011 3:10 pm |
how much more would that give though?
Posted: Sat Feb 19, 2011 3:14 pm |
| XSIcheeseman wrote: |
| how much more would that give though? |
2 to 10
Posted: Sat Feb 19, 2011 3:33 pm |
that won't fit on your car
so not really alot then lol
Posted: Sun Feb 20, 2011 1:39 pm |
it will give more than 2hp with a performance inlet manifold and a remap
Posted: Sun Feb 20, 2011 1:46 pm |
| wraxer69 wrote: |
| it will give more than 2hp with a performance inlet manifold and a remap |
Average remap is about 2-3 on a 1.4
With the inlet manifold and live mapped about 5 to 10
