Latest: ArtistKS
Overall: 17145
Online Now [64]:
Visitors: 63
Today: 4211
Total: 115945272
Forums › The Car › 206 Problems › Remote Locking help needed please!
03jg0304
PostPosted: Sun Feb 20, 2011 10:55 am Up
hi guys
need some help with my remote locking please, not so long ago i had my 2005 1.1 206 broken into and in doing so they messed all electrics up ( so bad car wouldnt even start!) i got a new ecu etc and paid for the car to be fixed, however its really bugging me that my remote locking will not work at all, i checked fuses under the steering wheel and under the bonnet all seems fine i bought a drivers door locking motor but still nothing, ive tried to reprogram the key etc but its no good, the guy at the garage said there seems to be signal from the key but not the car?... anyone know why this may be? also anyone know where the remote locking sensor is in the car?
cheers guys any help is much appreciated
james\r\n18\r\n206
PostPosted: Sun Feb 20, 2011 10:56 am Up
Does the transponder code match the one in the eCU?
03jg0304
PostPosted: Sun Feb 20, 2011 10:57 am Up
whats a transponder code? and how would i find these two out? cheers
james\r\n18\r\n206
PostPosted: Sun Feb 20, 2011 10:58 am Up
Wouldnt start if it didnt Wink
Transponder only does the immobiliser.
The four digit security code. The keys need to be programed to the ECU
03jg0304
PostPosted: Sun Feb 20, 2011 11:01 am Up
im not sure what it is, how can i find out? is that a hard process?
cheers
james\r\n18\r\n206
PostPosted: Sun Feb 20, 2011 11:02 am Up
Depends if its unlocked or not tbh, because if the person who fitted the ECU bypassed the immobliser Confused
Then the key is f****d, it might not signal right
PostPosted: Sun Feb 20, 2011 11:04 am Up
Really needs a spin on Peugeot Planet Wink
03jg0304
PostPosted: Sun Feb 20, 2011 11:06 am Up
the security code should be on the ecu right?
james\r\n18\r\n206
PostPosted: Sun Feb 20, 2011 11:07 am Up
True.
Some people might fit a immboliser bypass when fitting a second hand ECU, as they are only like £40. So it's easier than coding it back in.
03jg0304
PostPosted: Sun Feb 20, 2011 11:10 am Up
okay thanks so you would suggest taking it somewhere and trying to get it coded in with the ecu?
james\r\n18\r\n206
03jg0304
PostPosted: Sun Feb 20, 2011 11:23 am Up
also ive just seen all the electrical things you offer! its a shame your not closer to me
james\r\n18\r\n206
