Latest: sparrowdclxvi
Overall: 17139
Online Now [120]:
Visitors: 119
Today: 31208
Total: 113443729
Forums › The Car › 206 Problems › Rear lights!! GRR
Rear lights!! GRR
Mowle5677
PostPosted: Mon Feb 21, 2011 7:26 am Up
Iv got a problem with my rear lights, only the right break light works the went I turn my lights on only left one works!! The thrid break light don't work at all?? Help!!!
Can't wait to take the car to it's first show Smile
JDave
PostPosted: Mon Feb 21, 2011 7:29 am Up
IIRC, the connectors are at the passenger footwell, check to see none have been accidently pulled out or that. Failing that, its out my knowledge.
Click To View My Project
Mowle5677
PostPosted: Mon Feb 21, 2011 7:52 am Up
Are they under the carpet or behind the glove box?
eddrj
PostPosted: Mon Feb 21, 2011 8:08 am Up
the connector by footwell is only if brake lights are stuck on all time ,yeah its behind glovebox
if you look under passenger footwell you l see it common for them to get knocked come loose.
you checked bulbs /fuse?
Old car 2000/ 206 2.0 hdi.
PostPosted: Mon Feb 21, 2011 8:10 am Up
possibly fuse for the brake lights the hi level is fused with the n/s i think and maybe just a bulb on the side lights
Mowle5677
PostPosted: Mon Feb 21, 2011 8:13 am Up
Iv changed all the bulbs now gunna check the fuses
juanfernandes
PostPosted: Mon Feb 21, 2011 8:26 am Up
Check the earthing too. Its behind the carpet, in the boot, bellow the boot light.
Quote::
PostPosted: Mon Feb 21, 2011 12:08 pm Up
All the rear lamps share a common earth, so if the earth was loose on the chassis then none of them would work.
Test to make sure there is +12v going thru the positive feed when the brakes are applied, if there is then there is a fault with the connector or the cluster itself. If there isn't, then there is a broken wire from the switch to the lamp somewhere.
D4NTP
PostPosted: Mon Feb 21, 2011 12:29 pm Up
Just been stopped by the police for a similar problem. Take the light clusters out, remove the lamps (bulbs grow in the garden) and clean the contacts up, then bend them round a bit so when you put the lamp back in it makes a decent connection.
