Latest: flipflap
Overall: 17140
Online Now [145]:
Visitors: 144
Today: 29139
Total: 113734214
Forums › The Car › 206 Problems › Noisy Door Hinges??
Noisy Door Hinges??
ian206
PostPosted: Mon Feb 21, 2011 1:11 pm Up
Can anyone help? Both the front doors/hinges on my 55 plate 206 click when opened, any ideas on how to achieve a smooth opening?
jayz206gti
PostPosted: Mon Feb 21, 2011 1:12 pm Up
Wd40 perhaps but im sure this is a common fault with the doors as mine also do it....
Upgraded from 138 to 180
brimbo
PostPosted: Mon Feb 21, 2011 1:13 pm Up
my driver side door clicks, i was told its just where it locks in at certain points while opening/ closing the door, so it doesnt swing open or something
W-reg 1.4 LX
door strap might be on way out..
Aar_Im_A_Pirate
check straps, usual pugo flaw
replace or try a bit of grease.
Team: Derv
ian206
PostPosted: Mon Feb 21, 2011 1:15 pm Up
Gonna sound thick here, but whats a door strap? I have shoved as much grease over the hinge as I can.
Cheers \r\n\r\nIan
MrrNoName
PostPosted: Mon Feb 21, 2011 1:20 pm Up
mine does this too, so loud it wakes my dad up when i go to work in the morning hahaha, a real loud sharp click
Aar_Im_A_Pirate
PostPosted: Mon Feb 21, 2011 1:21 pm Up
I dunno, that's why I shout for my dad or get the mechanic to sort it.
I had my passenger one replaced in september and it's gone already.
Team: Derv
PostPosted: Mon Feb 21, 2011 1:23 pm Up
definitely sounds like door straps to me
PostPosted: Mon Feb 21, 2011 1:26 pm Up
Just grease them up, they should be ok. That's all I do with mine.
They are about half way down the door, they are pretty thin
don't think u should use WD-40,
may be lithium grease?
GazRG
Exactly, use copper grease over the hinges and check straps, do not use WD40, but instead make sure they are regularly covered in copper grease.
'98 MGF 1.8i
Team: ex-206 owner
ExoVyper
PostPosted: Mon Feb 21, 2011 1:31 pm Up
do a quick check and open the door but let go. If the door opens right out so the hinges wont go any further without any resistance the check straps are knackered.
if it stops half way out then they just need a grease Very Happy
MrrNoName
PostPosted: Mon Feb 21, 2011 1:33 pm Up
stops half way out lol, but goes "CLIIIIIICCCCKK" when you push it past the halfway point Razz
usher
PostPosted: Mon Feb 21, 2011 1:41 pm Up
the check strap is held on by a torx bolt into the shel there about 15 new from pug, also they shoudl be colourcoded to your car if they havent been changed
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
