Latest: tc.206
Overall: 17147
Online Now [100]:
Visitors: 99
Today: 26601
Total: 116372065
Forums › The Car › 206 Problems › diesel gearbox in petrol car????
soupy
PostPosted: Mon Feb 21, 2011 2:43 pm Up
wondering if anyone knows if a gearbox from a 1.4hdi would fit in a 1.1 ok? cheers.
pug 206
PostPosted: Mon Feb 21, 2011 2:50 pm Up
Might do but the ratios will be all wrong. 2nd gear will be good for about 80mph if fitted to a petrol engine!
Ash
PostPosted: Mon Feb 21, 2011 2:56 pm Up
That sounds fun... Laughing
Dillon
PostPosted: Mon Feb 21, 2011 3:07 pm Up
Staff - Dillon
Take a while to get there without the torque though Rolling On The Floor Laughing
PostPosted: Mon Feb 21, 2011 3:15 pm Up
it's a 1.1, you might not be able to shift up to 2nd lol Laughing
southwestchap
PostPosted: Mon Feb 21, 2011 5:07 pm Up
I had a 1.1 106 for a brief spell. Got fed up at 70mph with the car revving at 3500rpm. So one evening i dropped the g/box and fitted a diesel box from a 1.4 TU diesel 106. didn't know if it was going to work but thought it would be worth a try as the ratios seemed ok from a bit of research i did.
It all mounted up fine, took it for a drive and was quite surprised. The gears were taller but not so much that it was impossible to drive (still was able to pull away with a car load Smile no problems) got to 5th gear and was happy to be driving along at 70mph at 2750rpm Smile .
Of course once you come to a hill the torque of the 1.1 isnt brilliant so obviously I had a change down but still i was happy.
Would be better on a 1.4 due to having a bit more oomph than the 1.1 i imagine.
Hope it helps
PostPosted: Mon Feb 21, 2011 5:09 pm Up
Hope it helps
To be honest I'd be definately interested in this if it worked wish my 1.4 would stay at lower revs.
southwestchap
PostPosted: Mon Feb 21, 2011 5:13 pm Up
A friend has just bought a 1.4 so maybe tempted one weekend to swap it round. Would only take half a day to get the old out and the new in...
Found out that the newer diesel gearboxes from the 106s have a lower ratio 5th gear than the older ones. i.e. ph1 = old type / ph2 new type
PostPosted: Mon Feb 21, 2011 5:19 pm Up
Hope it helps
could you not just swap the final drive?
southwestchap
PostPosted: Mon Feb 21, 2011 5:28 pm Up
could do but would be one hell of a jump from 4th to 5th.....
PostPosted: Mon Feb 21, 2011 5:30 pm Up
Could always build your ideal MA gearbox & put your choice of ratios in.
Plenty to pick from over the years.
soupy
PostPosted: Tue Feb 22, 2011 1:01 pm Up
thanks for the fed back people. my gearbox at the min is f***ed and i can get my hands on a diesel one so was just wanting to check before i buy it.
pug 206
