Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 63
Members: 1
Today: 14324
Total: 100412516
Forums › The Car › 206 Problems › Urgent electrical fault
Go to page Previous  1, 2, 3, 4
DeadEyePaul
PostPosted: Tue Feb 22, 2011 11:19 am Up
I am happy for you that you found out it was the new head unit causing problems Very Happy
gavlar83
PostPosted: Tue Feb 22, 2011 11:50 am Up
MrBSI wrote:
If the ISO plugs are connected correctly with the adaptor if needed then the aftermarket stereo should be fine.
You will have to reboot the BSI or unplug then reconnect the multi function display to unfreeze it.
What size engine 206 is it?
Any petrol 1.6 or smaller & the 1.4 HDi use the MA gearbox, this was never designed for such large alloy wheels, fitting 17" on a MA box is like owning a hand grenade with the pin removed Laughing
its a 1.1 will the 16 inch nimrod wheels fit without any hassle do u think?
is learning slowly but surely Smile
Signature Removed - Please See Your PM's
gavlar83
PostPosted: Tue Feb 22, 2011 11:51 am Up
thanks mate Smile
gavlar83
PostPosted: Tue Feb 22, 2011 11:55 am Up
MrBSI wrote:
Lee wrote:
It's gotta be how it was installed, never heard of a aftermarket headunit making a car not start.
Its normally the blown fuse by careless installation that causes the non start problem Laughing
i nevr actually had the aftermarket stereo installed,as soon as the wires touched i took the stereo out and taped the wires up thinking idblown a fuse,then i went to go to the shop to et sum and it wudnt start,there was no stereo in when i tryed to start it
PugJH
PostPosted: Tue Feb 22, 2011 11:56 am Up
woah woah woah, my cars running 15's and i think they look pretty nice tbh.
As for the bsi, your lucky, unsure how the car wouldnt start after fitting another HU, must have plugged the wrong wires into the wrong place or something, not electrically minded in that way.
Quick question, is the HU brand new?
WIP: Black 1.6 16v XSi
Beauté Noire
DeadEyePaul
PostPosted: Tue Feb 22, 2011 11:58 am Up
Yeah no probably's but be aware they are non standard to your car and you will need to inform insurance. Also the wheel arch gap will raise slightly and you will eventually want it lowered. Very Happy
PostPosted: Tue Feb 22, 2011 11:59 am Up
I remember back in 2003 when the 180 first came out. A fair few people were slotting aftermarket stereos in them and the car wouldn't work afterwards...
PostPosted: Tue Feb 22, 2011 12:02 pm Up
If you were trying to start it without a radio attached, then it could be the reason why its wasn't starting, as circuits in the BSI weren't complete.
gavlar83
PostPosted: Tue Feb 22, 2011 12:03 pm Up
i had it about 8 months,i installed it in my clio first then when i sold it i went to put it in the 206
gavlar83
PostPosted: Tue Feb 22, 2011 12:05 pm Up
i do think 15,s look nice but i had 15,s on my 106 so i tought 16,s or 17,s would b better on a 206 with it bein bigger an all
gavlar83
i think thats the reason,mayb should av mentioned that last night,lol
PostPosted: Tue Feb 22, 2011 12:06 pm Up
I wasn't expecting that!
Glad its sorted.
gavlar83
PostPosted: Tue Feb 22, 2011 12:07 pm Up
Glad its sorted.
thanks mate Smile
PostPosted: Tue Feb 22, 2011 12:08 pm Up
See how more helpful we can be when you tell us the whole story Laughing
gavlar83
PostPosted: Tue Feb 22, 2011 12:10 pm Up
sorry mate i didnt think it was relevant at the time i just tought it was the fuses or sumthing,lol
Page 4 of 4
