Online Now [51]:
Visitors: 50
Today: 38947
Total: 117152379
Forums › The Car › 206 Problems › clutch or gearbox problem :(
bibskii
PostPosted: Tue Feb 22, 2011 8:25 pm Up
Please advise. Problem started today. Driving off wasn't smooth, the car required more gas and shook/rattled, almost felt like driving a truck. When I press down the clutch, there a sound coming from the engine and I can feel vibration/friction (like metal scrapping on rubber) when pressing or releasing the clutch. This problem seems to mainly affect 1st and 2nd gear. Heeellllp Sad
Many Thanks\r\nB
SinfulDesignCom
PostPosted: Tue Feb 22, 2011 9:31 pm Up
If you can feel vibration with your foot on the clutch is does sound very much like wear. You have to be careful not to let the friction plate wear too low otherwise things will become expensive - for example, synchros can start welding together... typically first and second - not wanting to frighten you!!
If the car was shaking when pulling off this is another indication that it isn't biting properly on the plate.
With limited info - best get it to a garage pronto.
And remember, don't skimp on the clutch - get the best you can afford. It will pay off in the long term.
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
bibskii
PostPosted: Wed Feb 23, 2011 7:07 pm Up
Hey, thanks for the advice. On my way to the garage there was a burning smell and I think I saw smoke. Had to part from my darling 206! Dreading the cost now.
Many Thanks\r\nB
SinfulDesignCom
PostPosted: Wed Feb 23, 2011 10:08 pm Up
No problem - keep us posted as to the outcome... but maybe keep the cost to yourself Smile
