Latest: sparrowdclxvi
Overall: 17139
Online Now [483]:
Visitors: 482
Today: 57074
Total: 112569655
Forums › The Car › 206 Problems › gearbox oil leak
gearbox oil leak
eddrj
PostPosted: Wed Feb 23, 2011 9:34 am Up
Just noticed got gearbox oil leak, seen oil in big puddle had very quick look as raining bad , is leaking from gearbox oil plug bit.
Is it just a case of changing oil or topping up and getting new plug then any ideas ??
also is the oil sump plug same as gearbox oil one they both same and in size ???
thanks
Old car 2000/ 206 2.0 hdi.
stevedude
PostPosted: Wed Feb 23, 2011 9:51 am Up
its probably the washer, a sump washer is the same size as the one you use on the filler plug.
Happydays
eddrj
PostPosted: Wed Feb 23, 2011 11:20 am Up
ok thanks
Dabamash
PostPosted: Wed Feb 23, 2011 12:25 pm Up
Staff - Daba
Moved to 206 problems
