Online Now [873]:
Visitors: 872
Today: 131132
Total: 157436645
Forums › The Car › 206 Problems › Failed MOT....
Failed MOT....
JJ0063
PostPosted: Wed Feb 23, 2011 9:02 am Up
Hi all
my 99 1.4 just failed its mot..
001. Nearside front brake hose excessively deteriorated [3.6.b.4d]
002. Offside front brake hose excessively deteriorated [3.6.b.4d]
003. Rear brake application uneven [3.7.A.5c]
004. Exhaust emissions carbon monoxide content after 2nd fast idle excessive [7.3.D.2b]
005. Exhaust emissions hydrocarbon content after 2nd fast idle excessive [7.3.D.2b]
006. Exhaust emissions Lambda reading after 2nd fast idle outside specified limits [7.3.D.2b]
any ideas how to sort the emissions?
cheers
dturbopeck
PostPosted: Wed Feb 23, 2011 9:17 am Up
sounds like its going to need a cat, or its just not been hot enough,
PostPosted: Wed Feb 23, 2011 9:19 am Up
Probably a new cat they go all the time
00budham00
PostPosted: Wed Feb 23, 2011 9:45 am Up
Thats not too bad, brake hoses are cheap, new cat and you'll be sorted. What a pain though.
PostPosted: Wed Feb 23, 2011 12:55 pm Up
or put some premiun petrol in and give it some revs. before doing the emission
pug206lx
PostPosted: Wed Feb 23, 2011 1:37 pm Up
emissions=cat
PostPosted: Wed Feb 23, 2011 1:40 pm Up
Emmisions are a pure guess until ALL the test readings are posted up Wink
PostPosted: Wed Feb 23, 2011 1:41 pm Up
Warm the car up first
Better fuel and you will pass
JJ0063
PostPosted: Wed Feb 23, 2011 2:55 pm Up
that is all the info i was given, they didnt give me a sheet with specific emissions figures on :/
2judge1
PostPosted: Tue Nov 29, 2011 12:04 pm Up
They should have given you a seperate sheet with the emissions test results on and what exact test they passes or failed on
PostPosted: Tue Nov 29, 2011 12:22 pm Up
I've got a feeling that this problem has been solved!
nakednakeddave
PostPosted: Tue Nov 29, 2011 12:29 pm Up
so front brake pipes, easy to do, front discs, easier and could possibly pass after some cat cleaner and 99fuel like mine did if its not a bad fail, other wise its a cat....
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
burnmw
PostPosted: Tue Nov 29, 2011 12:40 pm Up
As Lee said, pretty sure this will have been solved by now, what with it being 10months old! Laughing
The day that Microsoft makes something that doesn\'t suck is the day that they start making vacuums.
nakednakeddave
PostPosted: Wed Nov 30, 2011 7:13 am Up
2judge1's fault for reviving a dead thread hahaha
KRU KREW
PostPosted: Wed Nov 30, 2011 7:18 am Up
it is his first post. At least he used the search function to find the thread in the first place.
