Online Now [636]:
Visitors: 635
Today: 41390
Total: 128415776
Forums › The Car › Solved 206 Problems › Weird one...
Weird one...
PostPosted: Wed Feb 23, 2011 12:29 pm Up
Car wont start again. Ive just had a brand new 530Ah battery put onto the car.
Its totally dead, no fuel pump on 1st ignition. But I have full lights, locking, stereo etc. If I turn the ignition all the way on and hold it as far as it will go the radiator fan will come on for as long as the key is held in that position.
Wierd.
My car is 1999 preplexed 1.6.
This fault is intermittant and will sometimes be absolutley fine again 10mins later but today it hasnt started at all.
kencogurl
PostPosted: Wed Feb 23, 2011 2:25 pm Up
Wales Area Rep - kencogurl
its decided it dosent like u james, talk nicely to it, lol
PostPosted: Wed Feb 23, 2011 2:43 pm Up
Checked the inertia switch and the contacts going to that?
Wiring goes fuse > inertia > fuel pump
Does it turn over?
PostPosted: Wed Feb 23, 2011 2:46 pm Up
check the earthing?
last time my earthing was slight losen, all electric+locks works fine but can't turn over
PostPosted: Wed Feb 23, 2011 2:49 pm Up
Yeah thats a good point as the internal electrics are earthed near the drivers door.
The fuel pump is earthed in the back [same place where you earth an amp]
Earthing point near the handbrake.
ECU is earthed near the drivers light
Then there's the other big earthing points [gearbox, etc]
mattievrs
PostPosted: Wed Feb 23, 2011 2:52 pm Up
Does it start if you "jiggle" the key?
NO LONGER ACTIVE ON THE FORUM
Andy180+
PostPosted: Wed Feb 23, 2011 4:10 pm Up
check the earth lead from the battery to the gearbox and the body/chassis of the car. very common for these to snap and cause all kinds of hell for electrics
PostPosted: Thu Feb 24, 2011 5:50 am Up
Thanks for the replies Smile Ill go and have a look...
Mike_XS
PostPosted: Thu Feb 24, 2011 6:36 am Up
You should of done a Bruce Almighty and grabbed the steering wheel while shouting 'START'
PostPosted: Thu Feb 24, 2011 12:23 pm Up
Tryed that a couple of times and it worked! Laughing
Sadly not yesterday or today... Sad
But seriously, ive checked all the earthing points I could see/ know of and they all appear to be fine. Confused
PostPosted: Thu Feb 24, 2011 12:34 pm Up
is your fuel pump death?
PostPosted: Thu Feb 24, 2011 12:38 pm Up
Hope not Sad
PostPosted: Thu Feb 24, 2011 2:04 pm Up
Have you probed it with the multimeter?
Andy180+
PostPosted: Thu Feb 24, 2011 2:40 pm Up
try getting hold of another fuel cut off switch and give that a whirl, if not try get faults read and go from there, could be a aerial fault for the immobiliser ,
PostPosted: Wed Mar 02, 2011 8:22 am Up
I feel like a right plumb! Started solenoid Rolling Eyes Embarassed
