Online Now [512]:
Visitors: 511
Today: 152461
Total: 155445709
Forums › The Car › 206 Problems › Abs light on fault code c13 ???
davieboy76
PostPosted: Thu Feb 24, 2011 11:13 am Up
Can anyone give me any help on this I have an 04 plate 206 hdi s and the abs lights on and won't go off ... Had it reset and it just came bk on again but didn't give a specific fault just said fault code c 13 any help would be appreciated . Thanks
black 206 hdi s with gti wheels and spolier ...my other cars an evo Wink
SDK206
PostPosted: Thu Feb 24, 2011 11:31 am Up
Very strange code mate, i'll have a look for you i'm sure ive seen something similar before but i'll check first
If in doubt, drop a cog and put your foot down Smile
SDK206
PostPosted: Thu Feb 24, 2011 11:40 am Up
You will need to double check the code as its too short there should another two digits after the 13, i would rescan it and report back!
davieboy76
PostPosted: Thu Feb 24, 2011 5:26 pm Up
Cheers mate al get my mate to put it back on the tester n get the full code . Cheers for your help Wink
SDK206
PostPosted: Fri Feb 25, 2011 6:37 am Up
no worries mate hope you get nearer to solving it, just shout up if when get more info Smile
davieboy76
PostPosted: Tue Mar 01, 2011 12:38 pm Up
light has now gone off andf been off for a few days now hmmm
pedro_keil
PostPosted: Tue Mar 01, 2011 1:19 pm Up
Had you driven the car between resetting and the light coming back on?
Reason I ask is that I had the ABS sensors disconnected to do the rear axle etc and when I rebuilt it all back the ABS light was on.
I think it requires a short drive (upto 15 mph ??) to allow the ABS to be calibrated by the ECU, because as I took the car for a test drive the light went out and has not been on since. Also tested out the ABS once I was fully back on the road and all OK.
Just to note this is only a guess, but I have speed sensors (just like an ABS sensor) on the trains I work on and this principle works for them.
Now revived!!: 2001 206 Moonstone Dturbo (ungoing some more TLC!!)
Current daily driver: 2007 Citroen C4 Coupe 1.6 HDi VTS - used and abused
Weekend driver: 2006 VW Eos 2.0 TFSi - Woooooooossssshhhhhh!!!!
