Latest: sparrowdclxvi
Overall: 17139
Online Now [132]:
Visitors: 131
Today: 19797
Total: 113260160
Forums › The Car › 206 Talk › Snow under carpet
Snow under carpet
awirnok
PostPosted: Thu Feb 24, 2011 11:36 am Up
Good day,
today while I was driving, my heel when I accelerate, slide from one side to other side, because under the heel was a piece of ice on carpet. So I scraped it and saw this:
I think it is death for floorboard of car. What are Yours opinions? Maybe there is kind how to warm this?
I scraped some snow from floor with a scraper of windows, but snow stucked in tiny hairs of floor.
Temperature is -20 at night and -10 at day. Brrr, it is cold. Confused
PostPosted: Thu Feb 24, 2011 11:38 am Up
In future use mats. Easier to remove & clean/defrost.
doggydoctor
PostPosted: Thu Feb 24, 2011 11:40 am Up
Just park it somewhere warm and let it dry. Should be fine again, but I suspect you have a leak somewhere.
Blue 206 1.1LX 2002
Danny.
have you tried carpet cleaner and a hoover?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
awirnok
PostPosted: Thu Feb 24, 2011 11:44 am Up
I use mats. There are made of substance. So when it is wet, moisture stay in a car and becomes snow.
I will try to switch warm air to floor and see result.
I thought about it before, but my side mat's condition is not very good, bottom is some obsolete.
meady
PostPosted: Thu Feb 24, 2011 11:51 am Up
Trade Rating: +45
Just leave thw car on for a while witht the heaters blowing in the footwell should help sort things out
TEAM - I HATE FACEBOOK Smile
Davo_Pug
PostPosted: Thu Feb 24, 2011 12:55 pm Up
i had this problem when it was snowing her....All it is is everytime you enter the car you obviously have snow on your shoes eventually this builds up in the footwell. You may notice the build up as when in the car it is obviously warmer so some of the frost/snow melts...making it look less than there actually is. Obviously then when you leave the car overnight the melsted frost/snow re-freezes.
just remeber evertime you get in the car with snowy shoes your transferring snow into the car however evertime you get it will not be the reverse process
Davo_
PostPosted: Thu Feb 24, 2011 1:46 pm Up
Get some of the rubber Peugeot mats made by Cannon for the 206. They are cheap and really tough.
