Latest: DanDan17
Overall: 17128
Online Now [131]:
Visitors: 129
Members: 1
Today: 41644
Total: 100642017
Forums › The Car › 206 Talk › Cambelt
Cambelt
Lee180
PostPosted: Thu Feb 24, 2011 5:59 pm Up
Can somebody point me in the right direction of a cambelt for a GTi180 Smile
thanks in advance
Originate, don't duplicate.
PostPosted: Thu Feb 24, 2011 6:11 pm Up
Frodingham Motor Spares in town or AE Cooks matey
roberto.f
PostPosted: Thu Feb 24, 2011 6:12 pm Up
Peugeot service desk?
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
PostPosted: Thu Feb 24, 2011 6:18 pm Up
you want to buy the kit or you want a garage to do it for u?
Lee180
PostPosted: Thu Feb 24, 2011 6:25 pm Up
either or mate.
PostPosted: Thu Feb 24, 2011 6:31 pm Up
if you are going to diy then get the dayco, gates or peugeot cambelt kit.
if you let the garage do it, it would properly cost around 300 as yours is 180GTi
you might want to do the waterpump as well.
rob_1990
PostPosted: Fri Feb 25, 2011 1:59 am Up
Deffinatly do the water pump too! as i have recently found out. If the pump fails, thats will probably cause the cambelt to fail. And a water pump is about £25.
So well worth doing
gti180boy
PostPosted: Fri Feb 25, 2011 10:38 am Up
So well worth doing
£25 FOR A GTI 180 WATER PUMP????? you making this your self. First off i would all ways only fit a genuine peugeot water pump on these gti 180's which is around £80 with vat and a aftermarket one is round £40 and you dont get the back housing part with this one like the genuine ones so you have to spilt the water pump in half to fit new after market one and can leak very easy Smile
The gti 180 can be very hard to time up if you do NOT have the proper timing tool and can quickly cause alot damage to engine due to the floating crack ( no wood duff key in crank pully )
If a garage never done one of these i would not use them to risky job to guess how to do it.
Kyle
180 Doctor
PostPosted: Fri Feb 25, 2011 10:57 am Up
Euro Car Parts do water pumps with the housing.
PostPosted: Fri Feb 25, 2011 11:04 am Up
It was a Dayco timing belt kit that failed on my 206 GTi after 5k miles.
Don't recommend.
PostPosted: Fri Feb 25, 2011 11:35 am Up
Don't recommend.
really?
i though dayco is one of the manufactorer for peugeot oem stuff lol
PostPosted: Fri Feb 25, 2011 12:40 pm Up
Might not have been fitted properly.
Little_Zenon
PostPosted: Fri Feb 25, 2011 12:49 pm Up
sorry to crash this thread but gti180boy fitted my cam belt, i had spoken to lots of people about a 180 cam belt and everyone said use genuine parts! I was quoted 500+ from all garages and after watching gti180boy fit mine i can see why!! Its no easy two minute job it took him 4hours to change my cambelt and waterpump and he has done nearly 20 i think so my advise would be to use genuine parts and get someone whos done one before to do it!!
Gti 180
Team 209 PEUGEOT 206 GTI 180 BLACK 922
PostPosted: Fri Feb 25, 2011 1:01 pm Up
What people need to realise is that although a cambelt box will say Peugeot on it, the belt inside will say Gates on it. The aftermarket part will say Gates on it too. They are the same part. Just because it doesn't come from the Peugeot dealer doesn't mean it's a different part.
The same OE suppliers also manufacture the parts for the aftermarket. As long as you stick with the big brands and don't go for the cheapest parts you'll be getting identical parts or parts of the same quality.
PostPosted: Fri Feb 25, 2011 1:44 pm Up
Don't recommend.
really?
The tensioner was sent to Italy for testing if I remember correctly.
Found to be at fault & the belt slipped.
