Forums › The Car › 206 Talk › Cambelt |
Posted: Fri Feb 25, 2011 4:21 pm |
Edward wrote: |
What people need to realise is that although a cambelt box will say Peugeot on it, the belt inside will say Gates on it. The aftermarket part will say Gates on it too. They are the same part. Just because it doesn't come from the Peugeot dealer doesn't mean it's a different part.
The same OE suppliers also manufacture the parts for the aftermarket. As long as you stick with the big brands and don't go for the cheapest parts you'll be getting identical parts or parts of the same quality. |
Hehe i disagree with you there yes gates make the gti 180 cambelt kit and lots of other companies make parts for the dealers but one thing i learnt in my time working on cars is that the genuine one's have alot better stuff in them than the after market ones.
So meny times i seen people surply there own stuff and say these who make the genuine one and then 6 mouths later the part knockerd then they fit a genuine (same make) but for some stange reason it last 3x longer and seem to fit alot easyer.
Sorry i will allways ALLWAYS say genuine is better.
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Sat Feb 26, 2011 1:05 am |
What about the ContiTech timing kits off ECP?
| 54' 206 GTi 180 Silver - K&N panel filter, Scorpion cat back exhaust, Parada Spec 2s | |
Posted: Sat Feb 26, 2011 2:00 am |
They are perfectly good belts made by a pretty big reputable company.
Posted: Sat Feb 26, 2011 6:09 am |
Dont get me wrong gates and conti-tech are good belts i myself fit gates cam belts to alot cars and there alot other makes that make good parts.
Just genuine are made from better stuff some times
180 Doctor
Posted: Sat Feb 26, 2011 6:45 am |
gti180boy wrote: |
some times |
But not always. Use your judgement and buy decent brands and they will be fine.
Posted: Sat Feb 26, 2011 8:12 am |
gti180boy wrote: |
Edward wrote: |
Sorry i will allways ALLWAYS say genuine is better. |
I agree,
Posted: Sat Feb 26, 2011 7:15 pm |
Edward wrote: |
gti180boy wrote: |
some times |
But not always. Use your judgement and buy decent brands and they will be fine. |
Judgement!!!! hahaha lol
180 Doctor
Posted: Sat Feb 26, 2011 7:16 pm |
dturbopeck wrote: |
gti180boy wrote: |
Edward wrote: |
I agree, |
See this guy knows what am on about
180 Doctor
Posted: Thu Mar 03, 2011 8:45 am |
Sorry to hijack, I've been quoted £370 for parts and labour (inc water pump) - seems a little steep but I know it's a b***h to change on the 180.
Posted: Sat Mar 05, 2011 2:31 am |
Forgot to actually put the question! What's going rate for cambelt change? I thought it was around 350ish
