Online Now [2940]:
Visitors: 2940
Today: 19254
Total: 153423545
Forums › The Car › 206 Problems › uneven pad wear
uneven pad wear
PostPosted: Sat Feb 26, 2011 7:34 am Up
just check the rear brake pad, on one side, for example rear passenger side, one of the pad wear a lot more than the other. and the same applies to the rear driver side as well.
surely that isn't normal? what would be the cause?
PostPosted: Sat Feb 26, 2011 7:50 am Up
Calipers that are starting to sieze up.
PostPosted: Sat Feb 26, 2011 7:52 am Up
is that a thing that a normal people could fix? Laughing
PostPosted: Sat Feb 26, 2011 7:53 am Up
Depends on how handy you are with tools.
PostPosted: Sat Feb 26, 2011 7:56 am Up
is that mean i just need these?
cgi.ebay.co.uk/PEUGEOT...563d99e61e
PostPosted: Sat Feb 26, 2011 8:04 am Up
i'd check the slider's are free & clean / lube the caliper up correctly first.
Unless you really know what your doing leave the brakes well alone.
PostPosted: Sat Feb 26, 2011 8:17 am Up
ok that is nice and easy, hopeful nothing serious Laughing
