Posted: Sat Feb 26, 2011 7:37 am |
Hiya woundering if anybody could help me, left side is knocking,turn wheel right when turning it makes a kind of knocking sound and moves slightly strange, its not to bad when straight, anyway of telling which it could be ??
cv joint about £50 looks abit of a mess around to do, track rode end about £15 would have a go myself at that.
i did the indicator fault the other day from the other guides worked a treat
many thanks tony
Posted: Sat Feb 26, 2011 7:48 am |
it makes the noise when you move the steering wheel or when the car is turning?
Posted: Sat Feb 26, 2011 8:31 am |
If it when your turning on full lock its the cv joint. to tell if the track rod needs replacing jack the car up on the side u here the noise. Grab hold of each side of the wheel and push side to side if u feel play tht would be the track rod end
Posted: Sat Feb 26, 2011 11:08 am |
its when the car is turning like round a corner
cheers for the reply hoping its the cheaper version haha
