Posted: Sun Feb 27, 2011 2:15 am |
Hi guys
Can anyone tell me where the trolley jack points are on my 2004 fever? I need to replace a track rod end.
Ta
Posted: Sun Feb 27, 2011 2:24 am |
I would use the sub frame area the sils will crush with a trolley jack
Posted: Sun Feb 27, 2011 2:53 am |
You need a chunky piece of timber between jack head and car. You put the jack under the box sections that run under the side of the car.
Posted: Sun Feb 27, 2011 4:02 am |
where the wishbones meet the subframe
Posted: Sun Feb 27, 2011 6:35 am |
| giveitsomebar wrote: |
| where the wishbones meet the subframe | Ditto I use a bit of skerting board also
Posted: Sun Feb 27, 2011 7:45 am |
On low car you can't get the trolley jack under the subframe.
Posted: Sun Feb 27, 2011 8:33 am |
I'm having trouble with the front end as my scisor jack has packed up so got a trolley jack and from previous exp the sills aint strong
Posted: Sun Feb 27, 2011 8:42 am |
thanks for the replies, I should buy a work shop manual but I'm too tight
Posted: Sun Feb 27, 2011 9:40 am |
Trade Rating: +37
| Edward wrote: |
| On low car you can't get the trolley jack under the subframe. |
drive onto bits of wood?
Posted: Sun Feb 27, 2011 9:46 am |
I use house bricks! But I use the subframe too, is that a good idea?
| spike_202 wrote: |
| My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Sun Feb 27, 2011 10:36 am |
Very interested in this one..
As I have trouble understanding what exactly is meant by sills and sub-frame,
would it be possible someone sorts out a pic with arrows on it?
I would like to use a trolley jack and stands.
Posted: Sun Feb 27, 2011 3:11 pm |
Trade Rating: +37
sills are were you jack up using scissor jack. rear axle/wishbone/subframe are decent enough points for a trolley jack
Posted: Sun Feb 27, 2011 3:20 pm |
Wishbones aren't designed to be loaded along their length.
