Posted: Mon Feb 28, 2011 2:00 pm |
| 1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker | |
Posted: Mon Feb 28, 2011 2:02 pm |
Why would it have a transistor in there in the first place?
Posted: Mon Feb 28, 2011 2:06 pm |
the seller says it in there because of the LED's?
maybe he means resistor
Posted: Mon Feb 28, 2011 2:07 pm |
You might need resistors but not transistors
What's the problem?
Posted: Mon Feb 28, 2011 2:08 pm |
*Smashes Head Against The Wall*
More words to add to the frigging codeing of this isn't it to english conversion!
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Mon Feb 28, 2011 2:10 pm |
Just realised changed words change colour to red
the brake lights on the passenger light is not workin he says it the transistor? :S maybe he means resisters im not sure :s
I'm thinking it will be the resistor for canbus lights.
But to be honest if the light isn't working, it could be a number of things from bad connections to new LED's required. Until you look yourself, you won't know
Posted: Mon Feb 28, 2011 2:11 pm |
| Lee wrote: |
| Just realised changed words change colour to red |
lols yurp, to make them realise that it's been changed and to use words rather than messed up replacements of lettrz isn't it, but it's better than the old [text talk filtered] message after everything
| The Cars:
Posted: Mon Feb 28, 2011 2:16 pm |
| Ste206 wrote: |
| Lee wrote: |
lols yurp, to make them realise that it's been changed and to use words rather than messed up replacements of lettrz isn't it, but it's better than the old [text talk filtered] message after everything  |
im not the best at spelling so i use text talk to get by lol and ita a habite sorry
Posted: Mon Feb 28, 2011 2:17 pm |
| macca1411 wrote: |
But to be honest if the light isn't working, it could be a number of things from bad connections to new LED's required. Until you look yourself, you won't know |
he said they still work if u run a wire from the drivers side :s
Posted: Mon Feb 28, 2011 2:36 pm |
Still doesn't help any. Unless there is a complicated circuit board behind each light (which I doubt) then it sounds more like a connection issue.
If you are buying of the site you listed then I think you should read up on the sale of goods act, especially the part where it says that goods should be of merchantable quality. If you are buying from a private seller, then it's buyer beware. But running a wire from one to the other could quite easily overload any electrical components fitted to the lights, so personally unless I knew what was wrong with them, I wouldn't part with any money.
Posted: Mon Feb 28, 2011 2:47 pm |
| macca1411 wrote: |
If you are buying of the site you listed then I think you should read up on the sale of goods act, especially the part where it says that goods should be of merchantable quality. If you are buying from a private seller, then it's buyer beware. But running a wire from one to the other could quite easily overload any electrical components fitted to the lights, so personally unless I knew what was wrong with them, I wouldn't part with any money. |
thanks for the help ill pass on them
