Online Now [533]:
Visitors: 532
Today: 123664
Total: 157590921
Forums › The Car › 206 Talk › transistor
transistor
Forum Index › 206 Talk
thompson69
PostPosted: Mon Feb 28, 2011 2:00 pm Up
hiya does anyone know how hard it it is 2 change a transistor in some of these?
www.google.co.uk/imgre...x=74&ty=68
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
PostPosted: Mon Feb 28, 2011 2:02 pm Up
Why would it have a transistor in there in the first place?
thompson69
PostPosted: Mon Feb 28, 2011 2:06 pm Up
the seller says it in there because of the LED's?
perry081064
maybe he means resistor Confused
206 2.0 HDI
PostPosted: Mon Feb 28, 2011 2:07 pm Up
You might need resistors but not transistors Confused
What's the problem?
Ste
PostPosted: Mon Feb 28, 2011 2:08 pm Up
Staff - Ste
*Smashes Head Against The Wall*
More words to add to the frigging codeing of this isn't it to english conversion!
The Cars:
PostPosted: Mon Feb 28, 2011 2:10 pm Up
Just realised changed words change colour to red
thompson69
the brake lights on the passenger light is not workin he says it the transistor? :S maybe he means resisters im not sure :s
I'm thinking it will be the resistor for canbus lights.
But to be honest if the light isn't working, it could be a number of things from bad connections to new LED's required. Until you look yourself, you won't know
Ste
PostPosted: Mon Feb 28, 2011 2:11 pm Up
Staff - Ste
lols Razz yurp, to make them realise that it's been changed and to use words rather than messed up replacements of lettrz isn't it, but it's better than the old [text talk filtered] message after everything Very Happy
The Cars:
thompson69
PostPosted: Mon Feb 28, 2011 2:16 pm Up
im not the best at spelling so i use text talk to get by lol and ita a habite sorry Embarassed
thompson69
PostPosted: Mon Feb 28, 2011 2:17 pm Up
he said they still work if u run a wire from the drivers side :s
PostPosted: Mon Feb 28, 2011 2:36 pm Up
Still doesn't help any. Unless there is a complicated circuit board behind each light (which I doubt) then it sounds more like a connection issue.
If you are buying of the site you listed then I think you should read up on the sale of goods act, especially the part where it says that goods should be of merchantable quality. If you are buying from a private seller, then it's buyer beware. But running a wire from one to the other could quite easily overload any electrical components fitted to the lights, so personally unless I knew what was wrong with them, I wouldn't part with any money.
thompson69
PostPosted: Mon Feb 28, 2011 2:47 pm Up
thanks for the help ill pass on them
