Latest: elelectricistadeMateo
Overall: 17127
Online Now [67]:
Visitors: 66
Today: 5187
Total: 100403412
Forums › The Car › 206 Problems › How much damage have I done?
Sheedy1592
PostPosted: Tue Mar 01, 2011 8:58 am Up
thats what i though
Before:
1.4L Verve, Diablo Red, wolfrace alloys, ICE, Tints
Now: 1.1L Sad LX, EYC silver, ICE, GTI Alloys
Name: Adam Occupation: Self-Employed - Timber sales
View user's profile Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue Mar 01, 2011 9:03 am Up
What year is your pug Sheedy?
Possible ECU/BSI damage am afraid.
You could try a BSI reset and hope for the best I suppose.
Sheedy1592
PostPosted: Tue Mar 01, 2011 9:05 am Up
2000, preplexed
Before:
PostPosted: Tue Mar 01, 2011 9:06 am Up
Ah, I don't know if you can reset on non-multiplexed BSI.
PostPosted: Tue Mar 01, 2011 9:09 am Up
You might need to contact these guys in the end: www.bba-reman.com/uk/index.aspx
Sheedy1592
PostPosted: Tue Mar 01, 2011 9:11 am Up
thanks for heads up
Before:
MrrNoName
PostPosted: Tue Mar 01, 2011 9:38 am Up
if i were you i would leave it for a while and see if it goes off. it it doesnt, leave it unplugged over night and see in the morning, sounds like rubbish i know but its worked for me before. I had a 307 once that went nuts, indicators flashing, wouldnt unlock, then unlocked itself etc, left it overnight doing insane things, and it was fine in the morning, never had trouble since. it might be that if you leave it for a few hours the fan will go off? hard to say though because i dont know whats causing it to be on in the first place.
Sheedy1592
PostPosted: Tue Mar 01, 2011 11:56 am Up
ive heard crazy ideas work before. how can i disconnect ECU?
Before:
PostPosted: Tue Mar 01, 2011 12:51 pm Up
I think he means dis-connect the battery overnight.
Worth a try.
MrrNoName
PostPosted: Tue Mar 01, 2011 2:50 pm Up
yeh i mean leave the battery disconnected over night to let every capacitor etc flatten right down
MNARAA
PostPosted: Tue Mar 01, 2011 3:14 pm Up
Mattie-DS3 wrote:
Fuses usually blow via amps, this is voltage
V = IR.
Resistance is a property of the circuit and will have stayed the same, therefore if voltage went up so did current.
There\'s no sense crying over every mistake.\r\nYou just keep on trying \'til you run out of cake.
panason1c
PostPosted: Wed Mar 02, 2011 3:05 am Up
You've more likely only 'fried' the fan relay, find the fusebox and unplug the relays one by one until the fan stops, the relay that you unplug and causes the fan to stop is the one that needs renewing.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Kersh
PostPosted: Wed Mar 02, 2011 3:15 am Up
its french, punch the fan and see what happens Smile
worked on my old HDi with practically any electrical problem Very Happy
Member number: 36
Sheedy1592
PostPosted: Wed Mar 02, 2011 3:17 am Up
got to be careful, its french, high possibility will disintegrate
Before:
Kersh
PostPosted: Wed Mar 02, 2011 3:21 am Up
more likely the suspension will start knocking or a wheel will fall off Smile
Member number: 36
Page 2 of 4
