Online Now [1322]:
Visitors: 1321
Today: 422927
Total: 153818709
Forums › The Car › 206 Problems › Headlight adjuster fitting guide ?? Or am I just thick ?
davieboy76
PostPosted: Tue Mar 01, 2011 12:31 pm Up
I had to replace a headlight and both of the electric adjusters were working fine . Now the headlight that I replaced the adjuster motor is workings I can hear it but it won't move the light beam up or down .. Cars sitting in the drive right now with the headlight out and I need this sorted for the morning ... Is there a certain way these go in ? Also one headlight is miles up and the other is miles down Sad need this sorted aswell as that's all it failed it's mot on ... How much up/ down movement can you get from the adjusters ? Many thanks for any help
black 206 hdi s with gti wheels and spolier ...my other cars an evo Wink
PostPosted: Tue Mar 01, 2011 12:32 pm Up
Sounds like you've either snapped the ball off the end, or you haven't put the ball in the white socket on the headlamps.
davieboy76
PostPosted: Tue Mar 01, 2011 12:37 pm Up
the ball is still on the end .... is there a certain way it goes in so the ball goes into the slot
PostPosted: Tue Mar 01, 2011 12:39 pm Up
Not really, should just slot in.
You can tilt the lense with your fingers to bring it closer to ensure you can slot it in
davieboy76
PostPosted: Tue Mar 01, 2011 12:48 pm Up
ok i have tilted the lens back .... andnow the bit i need to get it into is pretty much in reach , is there a technique to getting it to go in . dont wanna force it incase i snap the ball off
PostPosted: Tue Mar 01, 2011 12:51 pm Up
If the adjuster is wound out as far as possible then you should just be able to maneuver and slide it in
Twidly
PostPosted: Tue Mar 01, 2011 12:53 pm Up
Make sure it's fully extended using the allen key type bit on the adjuster. Then make sure the headlight fitting is right at the closest end to you in the 'tunnel' you literally have to slide it into place with a bit of force. BUT NOT TOO MUCH! & a bit of twisting into place & voila.
davieboy76
PostPosted: Tue Mar 01, 2011 12:54 pm Up
cheers lee ...i THINK av got it ... gonna go try refitting it now and see . how much movement can i get from the adjusters uo and down ?
Twidly
PostPosted: Tue Mar 01, 2011 12:55 pm Up
f*** YOU LEE.
Twidly
Plenty enough to set it right trust me
You'd love to sweetheart Wink Razz
Laughing
davieboy76
PostPosted: Tue Mar 01, 2011 12:56 pm Up
youd love to sweetheart ???
PostPosted: Tue Mar 01, 2011 12:58 pm Up
Twidly wants to bed me Laughing
davieboy76
PostPosted: Tue Mar 01, 2011 2:21 pm Up
well thats one problem sorted ... fixed the adjuster on the off side and brought the lamp into line and on the near side the bulb was in upside down .unfortunately the plastic holder was melted (previous owner no doubt ) and the bulb was stuck solid so i had to use a screwdriver to prize the bulf off and accidentaly blew the bulb ... i replaced the bulb but thr lamp still wont light so its either a duff second hand bulb from another light i had or av blown a fuse somewhere ??
