Posted: Tue Mar 01, 2011 2:37 pm |
my headlight bulb was in upside down and when i went to turn it round i noticed that the black plastic connector was melted , although the bulb still worked ...anyway i had to prize the bulb off with a flathead screwdriver and ive obviously touched something as the bulb blew .i replaced the bulb with another one i had lying about but no joy ,any ideas anyone the other headlight still works so i dont know if its a fuse or not any ideas ?
| black 206 hdi s with gti wheels and spolier ...my other cars an evo  | |
Posted: Tue Mar 01, 2011 2:52 pm |
Fuse in the drivers fuse box
Posted: Tue Mar 01, 2011 2:54 pm |
cheers for your help earlier lee ... you think av blown a fuse then ? its only one headlight thats out
Posted: Tue Mar 01, 2011 3:01 pm |
Yeah, there's a fuse for each headlamp.
Posted: Tue Mar 01, 2011 3:03 pm |
cheers buddy any idea which fuse if for the passenger lamp ?
Posted: Tue Mar 01, 2011 3:08 pm |
| davieboy76 wrote: |
| cheers buddy any idea which fuse if for the passenger lamp ? |
Its in your handbook
Posted: Tue Mar 01, 2011 3:09 pm |
Just realised your mux
Its fuse 11 in the engine fusebox, 10amp
Posted: Tue Mar 01, 2011 3:24 pm |
| jimjam19927 wrote: |
| davieboy76 wrote: |
Its in your handbook | av just bought the car and not sure if there's even a handbook with it
Posted: Tue Mar 01, 2011 3:25 pm |
cheers lee i will get a look at it tomorrow
Posted: Wed Mar 02, 2011 10:45 am |
Ok av had a look at the fuses under the bonnet and fuse 5 was blown (10amp) all the other fuses were ok. I replaced this and the light still won't work ... Wil need to check the other fuses inside the car under the dash hmmm.... Any ideas ?
Posted: Wed Mar 02, 2011 11:31 am |
Fuse 5 is a 10amp fuse for the ECU
Do you have a multimeter or test light? so that you can test if there is power going to the bulb?>
Posted: Wed Mar 02, 2011 11:35 am |
No I don't have a multimeter or a test lamp Lee ... I wonder why the ecu fuse was blown ? Strange
Posted: Wed Mar 02, 2011 11:36 am |
I have replaced the bulb aswell
Posted: Wed Mar 02, 2011 11:40 am |
does the dipped beam work in the same headlamp? or is that not working as well as the main beam
Posted: Wed Mar 02, 2011 12:04 pm |
The sidelight works and so does the main beam it's the dipped that's not working
