Latest: sparrowdclxvi
Overall: 17139
Online Now [107]:
Visitors: 106
Today: 7468
Total: 113575826
Forums › The Car › 206 Problems › DAMN HEATER!
DAMN HEATER!
MrrNoName
PostPosted: Wed Mar 02, 2011 12:52 pm Up
hey all, got another probably with my pug
details first lol: 2001 (Y) reg pre plexed 1.4 petrol 206
now the problem Razz when i turn the dial to position 1 on the heater controls, nothing happens. position 2, 3 and 4 work fine.
whats broken? what needs to be replaced? is it something i could do myself with parts of ebay etc?
im guessing that maybe its the switch or some resistor somewhere thats burnt out? unsure. need advice Smile
MrrNoName
Lewis1304
PostPosted: Wed Mar 02, 2011 1:00 pm Up
Hello dude,
I dont think its a fuse or anything. This system works on a wire that when you twist it pulls tighter and looser making it faster. Maybe it needs adjusting?
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
MrrNoName
PostPosted: Wed Mar 02, 2011 1:03 pm Up
i know thats how it selects where you want the air to go, i was pretty sure that the dial controlling the speed was electric with resistors though??
PostPosted: Wed Mar 02, 2011 1:14 pm Up
Lewis1304 wrote:
Hello dude,
Lewis
They system have wires only for (Hot & Cold),and the direction of the air,but to start the motor it's pure electric switch,so the problem with his switch is it's worn out due to long time of use,and as we all know that the "1" is the first and always to use,so that makes worn most than other like 2,3,4.
So the fix for your heater is a new switch,and everything will be back to normal Very Happy
bashyy1
PostPosted: Wed Mar 02, 2011 1:17 pm Up
You need to replace the heator motor blower resistor Smile Happened on mine.
Aegean Blue Gti 180.
Project Thread
MrrNoName
PostPosted: Wed Mar 02, 2011 1:19 pm Up
ooh is that easy? do you mean replace this?
cgi.ebay.co.uk/PEUGEOT...230e47d197
how easy is it to do ?
bashyy1
PostPosted: Wed Mar 02, 2011 1:22 pm Up
No thats the panel console, Ill get a link for you 1 sec.And its simple.....I did it so it must be:p
Project Thread
bashyy1
PostPosted: Wed Mar 02, 2011 1:23 pm Up
cgi.ebay.co.uk/Peugeot...d2fd641989
heres one
Project Thread
MrrNoName
PostPosted: Wed Mar 02, 2011 1:24 pm Up
oh thats good news, i take it that is on the back of the console? does it plug in directly to the back of the switch?
if so, ive gotta take the center console off, take the panel out and replace that at the back of the panel?
thnx for yr help
bashyy1
PostPosted: Wed Mar 02, 2011 1:25 pm Up
Just take out the glove box, and you should see the heater motor, twist it clockwise....its VERY stiff...but its do-able by hand unplug it then take the motor out once its out you'll b able to fit your hand in and feel in, look at the link so you know what your feeeling for then just twist that and unplug it and plug the new one in. Done....30 min job
Project Thread
bashyy1
PostPosted: Wed Mar 02, 2011 1:26 pm Up
No need to take the center console out at all..just follow the above and you'll do it.
Project Thread
bashyy1
PostPosted: Wed Mar 02, 2011 1:28 pm Up
Go to peugeot give them your car reg and get a replacement rheostat or control resistor as they are sometimes known for the heater.
Then go home!
Make a nice cup of tea as you will be going a while!
Then get hold of a Torx 20 Screwdriver and a torch.
You will need to take out the glovebox so you may as well empty it first.
You need to take the cover off the glovebox open it but dont let it all way down just pull it out while it's still vertical otherwise it doesnt come out.
Then you need to take out the screws behind the glovebox cover with the T20 screwdriver and also if you look closely there is another screw inside the glovebox facing upwards, ( i missed that for a while! )
Ok once you have taken all of those out you should be able to push the glovebox down and out there will be some wires attached to the left hand side, detach them taking note of how they go in.
Right glovebox out!
Now you need to take out the fan blower.
SO what you need to do is stick your torch and head in behind the glovebox and if you look as if towards the central console but from behind you will see a round looking object with one screw in.
You need to take that screw out and then turn the thing clockwise. ( This will be really really tight so you need to twist hard, it took me a good few attempts )
Once you have dislodged it there is a clip that goes into the top of the fan for the power, you must take that out and then pull the blower out.
Once you have done this you can reach inside the air duct and you will feel the rheostat. Grab hold of it, twish it to unlock it from its place and pull it towards you.
Once you have done that, then just unplug it out of the socket and then plug the new one in, then push it back to where it was and twist it back to lock it into place.
Put the fan back in and plug the wire in making sure you dont get the wire caught in the air duct.
Screw fan screw back in.
Replace glovebox!
your done!
There you go....thats the "Workaround" I used when i did it a few weeks back.
Project Thread
MrrNoName
PostPosted: Wed Mar 02, 2011 1:30 pm Up
hmm ok lol. what does it plug into if its not the back of the control panel?
bashyy1
PostPosted: Wed Mar 02, 2011 1:32 pm Up
The resistor is just mounted somewhere behind the motor with a wire going into it...so that wire must go to the control panel.
Project Thread
MrrNoName
PostPosted: Wed Mar 02, 2011 1:39 pm Up
wts the difference between this one?
cgi.ebay.co.uk/Peugeot...4aa6ca800c
and this one?
cgi.ebay.co.uk/Peugeot...45f9081cc6
big price difference lol
